Question about KitchenAid Pasta Roller / Cutter Set
Where can i get replacement gears for kitchen pasta roller
2 Suggested Answers
SOURCE: we need to find a
Here's my solution. I purchased an 8mm zinc-plated brass hex standoff from http://www.mcmaster.com (part number 92080A053). It is 25mm in length and has internal threads for an M4 screw. It fit perfectly into the nylon gear plug without modification. I had a colleague from work bore out a hole with his drill press (removing the internal threads) and turn down the exterior with a lathe to create a weak spot (mechanical fuse). See the attached image for the finished product. It doesn't match the original dimensions exactly but it is close and will suffice. You don't necessarily have to do the extra machining work if you don't have access to that equipment, but as jeffrey_w325 states in his post, this part is supposed to be the weak link and fail first. If you don't machine the part down, just be extra careful when using the pasta attachment. Good luck!4_3_2012_1_04_19_am.jpg
Posted on Apr 03, 2012
Broken input shaft
KitchenAid doesn't sell any internal parts for the KitchenAid pasta attachments, the only thing to do is buy a replacement, if it is just the pasta roller you can purchase the KPSA, if not the others are just sold in the KPRA pack
Mar 07, 2014 | KitchenAid Kitchen Aid KPRA Pasta Sheet...
The knob on my kitchen aid pasta roller keeps getting stuck and i cant change the setting i need to be at
It needs either oil or the gear has slipped. A machine repair person, such as a sewing machine repair might be able to help you out for a small fee. Good Luck!
Oct 27, 2013 | KitchenAid Kitchen Aid Ravioli Pasta...
Kitchen aid pasta roller is locking up
You will need to follow your nose and carefully dismantle it to see where the fault is. As far as I am aware Kitchen Aid supply no parts for this accessory, it comes as a complete unit only.
Mar 24, 2013 | KitchenAid Pasta Roller Attachment
My Pasta Queen does not lock into the number settings
You are probably missing or have a bad cog in the setting gears.
Feb 24, 2013 | Marcato Atlas Pasta Queen hand-crank pasta...
Hi, you may have a broken shear shaft. Here is a link to replace it.
http://www.ebay.com/itm/KitchenAid-Pasta-Roller-Attachment-KPSA-Repair-DIY-Hex-Shear-Shaft-Replacement-/281539451678
It also comes with instruction on how to replace it.
Feb 12, 2013 | KitchenAid Pasta Roller / Cutter Set
Where can i get gears for kitchenaid pasta roller
Not a solution, just want to echo the problem. There are solutions for the shaft, but when I opened this up I found a stripped nylon gear attached to the shaft. Kinda sucks: I recently replaced the nylon worm gear in the mixer, now I have to do the same in the spaghetti cutter. I can't find the part or any mention of it anywhere.
Jan 17, 2013 | KitchenAid Pasta Roller / Cutter Set
KitchenAid Pasta Roller / Cutter Set Logo
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
