Question about Keurig Special Edition B60 Coffee Maker
B60 special edition clear water surge last couple ounces
Got the B60 Special. Ed. 1 month ago. Made good coffee (extra bold)
till now except could be hotter. But all of a sudden it now produces a clear water surge for the last 1-2 ounces. The coffee is so weak
it is not drinkable. I measured the med size with no k-cup and
it is 8oz. I am wondering if the water pump or whatever
monitors the water pressure could be failing.
  • rjmc77 Feb 15, 2009
    Turns out the problem is intermittent. Switching between K-cups and the reusable filter basket (for Starbucks) seems to get the machine confused if that is possible. We no longer have the surge of water, but now with the reusable it sometimes has very little pressure and water trickles out and makes a partial cup. But now the the pre-filled K-cups seem to be working again.
    So we found Tully's Bold Italian roast tastes similar to the Starbucks so we are not using the reuasable any more and the machine is working ok as of today. Go figure.
Have you tried Descaling? In the manual, it recommends Descaling every 2-3 months, even though you mentioned that you've had yours only 1 month. Worth a try, anyway.
I know they carry a water filter thru Keurig.com for less than $18 that you install right on the water pump in the water reservoir if you live in an area where the mineral deposits are heavy. It lasts 2 months and you can buy 6 replacement cartridges for $25. I just put one in mine today and it took less than 6 minutes to install (5 of those minutes were spent just soaking it in clean water).
If that doesn't help, you can call their Support Team @ #1-866-901-2739 between 7AM-12 Midnight EST. Make sure you have the serial # of your machine before calling. It's located either behind the drip tray (just pull it out) or on the bottom of the unit.
Posted on Feb 14, 2009
Blue light is flashing where the water goes and it says prime. it won't brew. what do i do?
Remove the water reservoir, then reinstall it to it's normal position. Refill or top off with the recommended bottled or filtered water to the max fill line.This will clear the prime message. If after you do the the above procedure at least two times, the prime message keeps coming back your machine has brewed its last coffee. If you bought it from Costco, I would recommend returning it there. Or If still within the 12 month warranty period, call Keurig.1-866-901-2739. Tell them and they will ship you a replacement.
Oct 02, 2014 | Keurig Special Edition B60 Coffee Maker
Keurig special edition b60 prime problem?
You may want to try this.
Simply trying to clear the lines often will work. And as you will see from the many comments below, by far the most reliable way to get your Keurig brewer working again is the "Slap and Burp" method.
Here is how you do it.
First, unplug the brewer and remove both the water reservoir and drip tray.
Next, hold the brewer upside down over the sink and slap the base a few times. And I mean really slap it.
Now put everything back together and try brewing again. Most of the time this works with a couple of good slaps. If not, try it again.
And don't worry, there are no laws against giving your Keurig a good slapping!
Apr 21, 2013 | Keurig B60 Special Edition Brewing System...
When my machine makes a cup of coffee it continues to drip water after the brew process - when you remove the K-Cup it dumps about an ounce of water.
There's a needle that punches a hole on the bottom of the K-cup. That needle is clogged. Poke it with a paper clip or a thinner wire to unclog it.
Aug 23, 2011 | Keurig Special Edition B60 Coffee Maker
Only brews half a cup on the largest cup setting?
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 26, 2011 | Keurig Special Edition B60 Coffee Maker
How do you de scale?
There are a couple of ways you can descale a coffee maker one of them is by using the Better Brew coffee maker descaler or you can use a home brew of 1/3 white vinegar and 2/3rd water.
Nov 01, 2010 | Keurig Special Edition B60 Coffee Maker
I just bought my Keurig B60 new from a neighbor who bought it and used it once. She didn't like it becuase it didn't fill up her cup. I've had a single cup Keurig for years, but it finally stopped...
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Oct 03, 2010 | Keurig Special Edition B60 Coffee Maker
The keurig spits water into the water resevore and does not make a cup without first turning off the machine and turning it back on several times
Sep 23, 2010 | Keurig Special Edition B60 Coffee Maker
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
515 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
