Question about Cooktops
Teka f47 problem
F 47 error code
PIC645F17E (Bosch) electric cooktop show error code er22. What does it mean ? How to repair ? Please help me ! Thank you !
The error code you posted is not listed anywhere. There is the error code "Error" for the oven which means oven overheating. If that's true then the problem is a bad oven power relay board.
This part has been discontinued. Bosch probably replaced it with a different part but I was not able to find the correct part number. You can talk to APP CSR and they will help you to locate the correct part.
Sep 05, 2016 | Cooktops
I have a frigidaire ples389dcc as soon as i plug it in it give me a pf code
Good Morning Paul, thank you for your post!
Based off what you have described your Frigidaire range, PLES389DCC, is providing you with an error code of "PF" and "F1" as soon as you turn it on. An error code of "PF" stands for power failure this could be a possible problem with your control panel or power cord.
The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F1" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Apr 10, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
I am looking for a supplier of Kupperbusch parts located in Australia
there is a site on the net that handles teka and kuppersbrusch
phone 1300-912-953 and is called appliancesalesdirect.com.au
It is a long shot but they may be able to advise who will handle your problem
Jan 31, 2015 | Kuppersbusch Cooktops
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
How do you clear er
Hi friend, thank you for your inquiry!
I understand that you are receiving an "ER" error code on your Frigidaire range and you want to clear the code. "ER" stands for error, I would recommend performing a reset which can be done by flipping the household circuit breaker for roughly ten minutes. That should clear any false error codes. If you continue to receive an "ER" or any different codes please provide that feedback. I hope this helps. -Matt
Aug 23, 2014 | Frigidaire Stove / Oven / Range Cooktop...
What is ge error code 0225
I have the same issue and was told by GE that it will take a technician to fix it because it is not a known error code. Most error codes start with "f", F0, F1, etc. This the second time a tech had to come out for this cooktop. Probably the last GE I buy. Definitely won't buy anything electronic. I want regular knobs on the next one.
May 05, 2014 | General Electric Ge Profile Pp975bmbb 36...
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
Whirlpool error code e2 f3
The error codes are in the operating instructions if you don't have it ask Bosch to email the error code page to you.
Apr 10, 2014 | Bosch Cooktops
E30ic80iss electrolux error 31
Good Morning D, I am happy to assist you. Error code E31, commonly refers to an internal generator error in the left side cooking zone and that the generator control board needs replacing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, I would recommend connecting with an experienced appliance repair tech to assist further.
Jul 30, 2013 | Electrolux E30IC80ISS Cooktop
Electrolux E 95 code
Hello Robert - Typically, error code E95 indicates a power voltage miscommunication to the main components of the unit. You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then I would recommend contacting a professional to proceed further.
Apr 25, 2013 | Electrolux 36" Electric Hybrid Induction...
Cooktops Logo
209 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
