Question about Omron HR100C Heart Rate Monitor
Does not measure heart rate
Have changed batteries in chest strap and nothing previously heart rate was eratic and incorrect
  • Anonymous Feb 15, 2009
    heart rate starts out ok then rapidly climbs to over 200 then back to 0. Goes back to normal when I stop walking. Changed the battery with no improvement.
  • 74 Answers
This link takes you to customer service and troubleshooting...I hope this helps.
http://www.omronhealthcare.com/product/1131-187-fitness-diagnostics-pocket-pedometer-hj-112
Posted on Feb 02, 2009
Sportline cardio 660
Try to humidify contact area on chest strap(each side front). Also batterie weak in strap?
May 11, 2013 | Exercise & Fitness
Tip
Trouble with heart rate monitor reading heart rate.
Can't get a heart rate to show on your heart rate monitor? If there are no other issues with the watch, then most likely what you are experiencing is an issue with the Heart Rate Strap.
It is very common for all brands of heart rate monitors to have issues with measurement.
The #1 reason is poor contact with the strap and your skin. - Make sure the contacts are wet and touching the skin with good contact.
#2 reason - Weak battery, may need to replace.
#3 reason - Sensors on strap have salt build up from sweat - Clean the strap and contacts with soap and water, if deep cleaning is neccessary use a q-tip and some rubbing alcohol.
#4 reason - Strap is too low on the body, raise as high on the chest as possible to just under the breasts. Strap too low will cause a weak signal.
If none of these seem to help, then you should contact an authorized repair center or the customer service for your brand, and see about possible repair or exchange/ return.
on Dec 06, 2010 | Watches
Replace batttery in omron heart rate monitor chest strap
Check out this manual of the Omron heart Rate Monitor. It will help you in solving your problem.
http://www.omronhealthcare.com/wp-content/uploads/HR-100CN_A_M10_120221_web.pdf
Aug 06, 2012 | Omron HR100C Heart Rate Monitor
How do I enable my EFX 544 to give my heart rate while wearing my polar heart rate chest strap?
If the EFX 544 has polar Heart Rate attach to the upper electronics your chest strap should be transmitting and the unit should be receiving. If your chest strap is more than 3 yrs old usually the battery will die and needs to be replaced or you have a defective receiver and will have to be replaced
May 17, 2010 | Precor C956i Treadmills with HR /...
My heart rate monitor keeps stopping picking up my heart rate (reading of 00 or --), i have changed the battery in the chest strap, not difference, any ideas?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all POLAR watch manuals. Rate me, please.
Mar 03, 2010 | Polar F11 Heart Rate Monitor
Watch won't read heart rate
It could be the battery on the strap is not good. However just to be sure make sure you are wetting the strap and it is around chest, front should sit right about on the bottom of pectoral or chest, if you are female make sure it is under your sports bra the bra band will be over it. I would start warming up then hit the start button it should work.
Feb 06, 2009 | Polar M61 Heart Rate Monitor Watch HRM M61
My Polar HR monitor ce0537 do not pickup Hart rate
Had the same problem. Just figured it out. The center Polar Logo on the strap needs to touch your chest in a firm way. Bend it back slightly so it fits snug on the middle of your chest.
Jan 31, 2009 | Polar S410 Heart Rate Monitor
Timex M515 Heartb Rate Monitor in correct readings
I´m experienced the same problem of incorrect readings after a long time without use. I cleaned the rubber parts of the chest strap with soap and water, than I use some silicone grease or other silicon liquid to keep the rubber hydrated. Make a careful cleaning in the contact area between the rubber and the plastic parts, the fissure in these area use to be full of "sweat dust".
Jan 03, 2009 | Timex Digital 30 Lap Heart Rate Monitor...
Polar F11 not responding
I' advise to start with battery check. If the battery is ok, then you will need a professional to find the cause of malfunction.
Dec 19, 2008 | Polar F11 Heart Rate Monitor
HRM troubleshoot
A HRM is a training tool that helps you do cardiovascular (CV) training correctly, neither too hard, nor too easy. It’s almost like having a personal coach on your wrist! Every HRM comes in two parts: 1. An elasticated chest strap which contains a pair of sensors that detect and transmit your heart rate. 2. A wrist worn receiver that receives the signal from the chest strap and displays your heart rate. The receiver may also have additional functions and display other information depending upon the HRM model chosen. Both the chest strap and receiver are battery operated.
Aug 27, 2008 | Welch Allyn Spot Vital Signs Monitor
Omron HR100C Heart Rate Monitor Logo
513 people viewed this question
Top Omron Exercise & Fitness Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
JonSnell Electronic
JonSnell Electronic
Are you an Omron Exercise and Fitnes Expert? Answer questions, earn points and help others
