Question about Onkyo TX-SR304 Receiver
Power won't stay on my onkyo tx sr304
Got slightly wet. Turned power off, unplugged it, disconnected all the wires, removed the top encasement, dried it with a hair dryer even though it didn't appear wet inside. Following the manuel waited 1 hour turned it on set volume to max and the protection keeps turning it off. What can I do next if anything and is it worth the effort.
  • 4234 Answers
SOURCE: Onkyo TX-NR905 Protection Circuit Activated
The problem is not with the inputs. This unit is in protect because a problem has been detected in the output section. Try disconnecting the speaker wires and turning it on. If the unit remains on, there is a short in one of the speaker wires. If the unit still shuts down, there is an internal problem that will require repair. It sounds like this is a new piece. If so, it should be covered under warranty.
Keep us posted,
Dan
Posted on Jul 28, 2008
SOURCE: Reciever turns off
North American models are all set to 6 ohms. You can't switch the setting.
Try reconnecting the speaker wire into the back of the unit. This worked for me.
Posted on Dec 27, 2008
  • 24 Answers
SOURCE: onkyo tx-sr602 as soon as i turn receiver on it flashes protect
Does it display any message like "Protect" or something similar? Do you hear a relay click on then off?
Did the amp just not power up one day or did it stop working while you were listening to it? Finally, do you have teenage kids who might have been listening to your receiver and would have "neglected" to tell you that after listening to their music it suddenly stopped working?
It could be an internal fuse but chances are its something that requires a technician to repair (like the output transistors).
Posted on Dec 29, 2008
freetek
  • 5568 Answers
SOURCE: Onkyo TX-DS989 not staying on
This sounds like the action of some protection circuit that is monitoring some condition or voltage that isn't within its design limits. If it was mine, I'd look for an Onkyo forum to see if others have experienced the same problem.
Posted on Jan 08, 2009
gokomets
  • 120 Answers
SOURCE: My Onkyo TX-SR606 is frozen! It won't shut off and buttons don't
weird problem! how does it work with the "remote"?
Posted on Apr 11, 2010
I lost my owners manual for my onkyo av receiver tx sr304. Can you please send me one.
Here is the pdf http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=TX-SR304_En_0124.pdf . I found it on Onkyo's support page http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
Feb 28, 2011 | Onkyo TX-SR304 Receiver
Tip
Download Onkyo TX-SR304 Manual
Download Onkyo TX-SR304 Receiver Users Manual
Have you misplaced your Pioneer Download Onkyo TX-SR304 Receiver Owners Manual?
Would you like a digital, searchable, pdf version of the Download Onkyo TX-SR304 Receiver Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 20, 2010 | Onkyo TX-SR304 Receiver
How to program remote control?
Your Onkyo TX-SR304 receivers remote (RC-645S) is not capable of controlling devices by other manufacturers. It controls only Onkyo devices.
Other Onkyo remotes do have universal remote functionality and you can download Onkyo remote codes here.
I hope that helps.
________________________________________
Download Onkyo TX-SR304 users manual here.
Mar 26, 2010 | Onkyo TX-SR304 Receiver
I have a onkyo tx sr304 and a onkyo 6 disc player dx-c390.When my cd gets to disc 4 and 5 it shuts the receiver down.Whats up with this?
The only possibility that comes to mind is that it may be causing a short somehow when the carousel gets to that position, maybe a broken solder joint. Another possibility is that there may be a foreign object stuck inside the player such as another disc that lost it's position.
Feb 19, 2010 | Onkyo TX-SR304 Receiver
I have "Onkyo TX-SR304E" and PS3. Will this rcvr support PS3 in all means? Is there any special setting hat I ned to follow to get the best from my rcvr as well as PS3? Pls advise. Your help much...
what u can utilize on your tx-sr304 is the optical input at the back of the receiver. connect an optical cable from your PS3 into the receiver then follow these steps:
*make sure that the digital input on the front panel of your receiver matches where you placed the optical at the back of the tx-sr304 (either OPT1 or OPT2)
*all you have to do is keep pressing the digital input at the front panel until it goes to OPT1 or OPT2 (preferrably stay on DVD mode)
AFTER completing this go to your PS3 settings:
go to settings / then go to sound settings / then audio output settings / then set it to DIGITAL OUT (optical)/ then play and enjoy.....ü
Mar 05, 2009 | Onkyo TX-SR304 Receiver
TX-SR304 AV receiver
If you put DVD with Dolby Digital soundtruck it will show on your TX-SR304 Dolby Digital mode, and if you have DVD with DTS mode it will show DTS
Jan 17, 2009 | Onkyo TX-SR304 Receiver
Need codes for universal remote
Not sure if this helps, but I just called Onkyo with a request for codes for the SR304. They said the only codes they have are for THEIR remote. Maybe they will work with yours. Here they are:
0276 0476 0810 1187 1376.
I tried these in the Comcast remote (adding a 3 in front of the numbers) but that didn't work. Still trying to get my Comcast remote to program the Onkyo SR304 adequately, since their published codes only partially work.
Dec 30, 2008 | Onkyo TX-SR304 Receiver
Onkyo TX-SR304
Onkyo offers access to manuals at their web site. HERE is a link to the receiver line.
Personally, I'd connect the speakers to main left/right. The subwoofer to subwoofer out. The Go VIdeo unit to VCR/Video 1, the cable box to Video 2 and the video output to the Sony TV composite input. No need to connect the TV audio out to the receiver since the audio feed comes from the cable box.
Jan 13, 2008 | Onkyo TX-SR304 Receiver
Onkyo TX-SR304 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
