Question about Motorola Mobility MOTORAZR maxx V6 Cellular Phone
Moto v6 keypad problems
No buttons on my keypad work accept my hang up (turn on and off button) Hellp
  • 7 more comments
  • agent bond Nov 08, 2007
    My V6 keypad is having the same problem. The technician said we have to replace the "flex". How true is that? Help!
  • Blackfella Jan 09, 2008
    I have same problem, totally frozen. Cannot just be the keypad as side buttons do not work either.
    Phone shops bloody useless....
    Got to be a Motorola fault, but i cannot find support
    I think they should be recalled and fixed. I feel like throwing it but they are too expensive
    Any further suggestions appreciated
    Cheers
    gblack5@bigpond.com
  • jmct1977 Jan 13, 2008
    i have the same problem, any solutions???
  • Natalie Donald Feb 06, 2008
    none of my keypad is working....
    except the on and off button
  • sicknarf Apr 28, 2008
    Got Motorola v6 maxx and have the same prob, i can switch it on/off by its key but all other keys are not functioning, what should i do? Any help?
  • demoboy Jul 05, 2008
    the same thing happened to my V3x and my V6 maxx. Help
  • t_wells70 Jul 10, 2008
    Motorola Maxx V6 keypad locked can only turn the phone on and off.........what can I do???
  • shandsp Jul 12, 2008
    I have same problem, totally frozen. Not only the key pad but also side buttons do not work either.
    Phone shops are of no use....
    Seems to be a Motorola fault, but i cannot find support
    To whom to appeal now
    GOD save me........MOTOROLA.
    E-mail ID......shan.pcw @gmail.com
  • Anonymous Jan 22, 2009
    all the key pads dont work
Hey,
I have or should I say I had the same problem with my v6 maxx keypad not working. So I started to look into the flex cable replacement idea. I remove the back cover. Removed the Sim Card, Battery and Memory card fully intending to split the phone and have a look around inside. But then I came to a grinding stop when I saw how small the hex screws are. Gotta get me some of those. While I was there staring at the screws I noticed a small amount of dirt residue inside the back of the phone so figured it wouldn't hurt to give it a spray with CRC Contact Cleaner (it leaves no residue). I left the mobile in the sun to dry for about 3 minutes. Replaced the battery, memory and sim card and now it's working PERFECTLY.
Done. fixed. *** twas just dirt.
Cheers
roddarockker
Posted on Jan 13, 2009
Ive had the same problem.the volume key blocked my phone!!!!!!!!!!!!!!!all the same ,as above mentioned, the only key that worked on the phone was the power on/off key!i readed posts abowe and since i have no special screwdrivers to open the phone and clean contacts i thought to try something> just to put a little bitt of alcohole on every button on the flip./volume,camera button etc./ without opening the phone at all!!!!<i did this,put out battery from phone let him without battery about 2 hours until he dryes ,put battery back,turn on phone and wola it works!!!!!!!!!!!the whole problem is in dirt in buttons on the flip of the phone,probably it comes from hands during carring phone around etc.this is how i solved my problem.i hope that this is good for all that share the same problem!regards from serbia.
Posted on Jul 16, 2010
Try to reflash your phone
Posted on Mar 29, 2008
Hey. Mine has the same problem and the supplier says it liqiud damage which I disputed. A friend opened it up thinking all the damage was done and found a black mark on the contact plate,he cleaned it off and wiped it with a silicone spray not to dissimilar to DWD. Problem is fixed by I sitll believe it the manufactures problem
Posted on Mar 01, 2008
Yo i had one with the same problem wat i did u know u have the volume key on the side take out the down part it work i did my one please let me know if it work jonathanwilze@yahoo.com small contact just take that of i did and it work
Posted on Aug 15, 2007
SOURCE:
Does not overwrite old codes, just keeps accepting new ones. How can I clear all existing codes?
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Jan 27, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
My phone buttons are not working
Hard Reset:
Either through the menus or:
1. Turn the Moto Q off
2. Hold down the power button (hang up button) and the center key button (the button between the arrows) at the same time.
3. When the verizon logo appears on the device. Let go of both buttons.
4. A screen will come up saying to do a Master Reset. You will hit the left soft key to say yes to confirm.
Your Moto Q is now been hard reset ( Master Reset ) without having to go through the menu of the device.
There's currently no other way to reset your phone without using the buttons so.
If you are having problems with your Q already (since they were just released a few weeks ago), don't be afraid to exchange it for a new one.
The Motorola Q tech support line that I called was 1-800-657-7576.
Aug 23, 2010 | Motorola Mobility Moto Q
Keypad not working v9 moto
The volume buttons on the side of the phone are sticking. My up volume button seemed fine, but someone told me to keep pushing it and the button will release. Sure enough, the volume controls started to work. I played with both the up and down buttons some more and the button below started working. A few more minutes monkeying around with the volume buttons and now all the buttons work.
Jun 01, 2010 | Motorola Mobility MOTORAZR2 V9 Cellular...
Have a Rona electronic lock (Weiser) and the key works... will lock electronicly... but do not know the code... I have removed it from the door and replaced, but is there a way to reset the code?
I guide you...
Jan 23, 2010 | Weiser Lock Powerbolt 1000 Lock
Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Aug 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to reset password on my phone
Jun 27, 2009 | Motorola Mobility Moto Q
Moto w30 keypad not working
buy a new phone. your phone is buggered
Jul 03, 2008 | Cell Phones
Motorola Q power button
This is a difficult question to answer. First, make sure you did not accidentally drop any liquids on your keypad. Second, try removing the battery and replacing it. Thirds, try a Master Reset (Start, System Tools, Master Reset) BUT REMEMBER THAT A MASTER RESET WILL CAUSE YOU TO LOSE ALL PERSONAL DATA. After that I am afraid you may have to turn your phone in on an insurance claim. Good luck.
May 29, 2008 | Motorola Mobility Moto Q
Motorola v6 keypad issues
Your phone possibly got wet and thus your screen flex cable connection needs to be cleaned up with some contact spray or maybe your flex cable needs replacing to solve this problem.Contact a good service tech to get this problem rectified. At least you know what your problem is so now you could get it solved. Sam!
Jul 13, 2007 | Motorola Mobility MOTORAZR maxx V6...
Motorola Mobility MOTORAZR maxx V6 Cellular Phone Logo
951 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
