Question about Mr. Coffee BVMCPSTX91
Display Dim Mr Coffee PSTX
Display is very dim, can't read with room lights on
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
Fgmv174kfb dim display
The owner's manual (here) does not mention that as a feature, so I would assume the oven has a defect and would need to be returned to your dealer to be exchanged under warranty.
Oct 25, 2012 | Microwave Ovens
Can't see digital indicators in day light to dim
Your back-lit display light is either burnt out or the fuse is blown. It may be a more serious problem that needs expert attention. i.e. a mechanic
There could be a circuit board that controls the back light that has gone bad like I had with an LCD monitor once.
Sep 12, 2012 | 1994 Ford Aerostar Extended
What are the best picture settings for my 55 inch lcd 1080p 120hz tv?
Generally speaking, it comes down to persnonal preference - i.e. what looks good to you, the owner.
However, some techies are of the opinion that extreme (i.e. maximum) settings in your CONTRAST and BRIGHTNESS, can over time, reduce the lifespan of your TV's panel display.
Many of the current TV's on the market, now have built-in ambient light sensors, which allow your set to automatically dim the display, when the sensors detect very low room lighting. This is also an energy saver function on some TV's, which can be manually turned on/off.
Hope this helps.........
Nov 01, 2011 | Philips Televison & Video
Monitor dims when we turn lights off in room.
You need to give a more detailed description of the problem.
The LG 47LH90 is an LED backlit TV with 'local dimming' technology. This means that there are lots of white LEDs behind the screen and these can be controlled in groups to allow localised areas of the screen to be dimmed to produce better contrast between light and dark. It is very likely that when the room is dark, this local dimming is more noticeable. The actual individual LEDs cannot be controlled and so the area that is dimmed will generally be greater than the area that is required to be dark 'blooming effect'. In addition, LED backlit displays only maintain their contrast through a tight viewing angle. If you sit too farto the right or left, then light from non-dimmed LEDs will leak through and the screen will look lighter.
In short, there may not be any fault with your TV.
Jul 12, 2011 | LG 47LH90 47 in. HDTV LCD
What is opc light on my sharp aquos tv
This can be called Optical picture control and it adjust to suit the room light.
Please read the text below"
Dynamic Backlight Control - One of the nice features of the Sharp AQUOS LC-32D6U is what Sharp calls OPC, a name they use for their dynamic backlight control. You might also see this feature referred to as a dynamic iris on other LCD HDTVs or disguised under some proprietary name, but fundamentally the principle is the same. Its primary function is to try and maintain a high Full On/Off contrast measures the ratio of the light output of an all white image (full on) and the light output of an all black (full off) image. 2) ANSI contrast is measured with a pattern of 16 alternating black and white rectangles. The average light output from the white rectangles is divided by the average light output of the black rectangles to determine the ANSI contrast ratio. When comparing the contrast ratio of video devices make sure you are comparing the same type of contrast. Full On/Off contrast will always be a larger number than ANSI contrast for the same video device.">contrast ratio under any lighting condition. So when room lights come on or off or the sun enters the room, with OPC enabled, the backlight in the LCD will dim or brighten depending on the amount of light in the room. This is managed by a light sensor located on the front of the unit. When OPC is enabled there can be a slight reduction in the dynamic range of the display as the display attempts to maintain contrast and color saturation as room light changes. We had a chance to compare this feature with another LCD HDTV that was of comparable size but without dynamic backlight control, and the Sharp AQUOS LC-32D6U with OPC enabled was the clear preference.
Jan 24, 2011 | Sharp Televison & Video
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Display Panel Light
There is a replacement display assembly, i think its around $150-$200. Its pretty easy to change if you are at all mechanically inclined. Good Luck!
Oct 29, 2006 | Jenn-Air W30400P Stainless Steel Electric...
Mr. Coffee BVMCPSTX91 Logo
1,509 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
