Question about S.T. Dupont Watches
Where chan I get my DuPont lighter repair - S.T. Dupont Watches
I need to buy a butane tank for my Cartier lighter from the 80's, Cartier wont sell me one unless I agree to repair the entire lighter. So where in NYC can I find a place to purchase a tank?
If you can't find a used reservoir tank on eBay then you'll have no choice but to have Cartier service the lighter. Nobody sells new ones other than Cartier.
Apr 03, 2012 | Watches
Lighter was dropped and the gas reservoir leaks continuously
Gas leaks in a lighter most commonly come from one of two places: the refill port, where you charge the lighter, and the exit port, where the gas exits to be burned.
To confirm where the lighter is leaking, try immersing the refill port in some water. If the lighter is charged and you see bubbles, that's the source of the leak. If you don't see a leak there, try holding the top of the lighter briefly under water to see if it bubbles there. Because electronics may be present at the burn port of the lighter, you want to make this immersion as short as possible. You also want to let the lighter dry completely before attempting to light it again, so you don't accidentally short-circuit something. If you're really worried about shorting it out, you can dab a bit of a soapy solution on the burn port with a Q-Tip instead of immersing the whole lighter tip in water.
Imagine the refill port like a bicycle valve--when you push down to open it, gas can flow in (or out). When you release pressure, that port is supposed to close up again completely. If it is not closing correctly, you can try to look for a piece of something--a shard of plastic or metal, a tiny grain of sand--that is preventing it from closing. However, because this valve is pretty well protected, it's less likely to be the source of the gas leak than the burn port.
The burn port is opened and closed by a mechanical switch. Possibly, a little door flaps open or you push a lever. Each of these triggers opens the burn port, and letting go of the control is supposed to let it close again. If you dropped the lighter on its head, it's possible that the linkage controlling things may have gotten bent or even broken. In that case, the gas port may no longer be closing properly.
The bad news is that once you have diagnosed your gas leak, you don't have a great many repair options. It may be possible to repair a bent or disconnected control at the lighter head, but it is rarely cost-effective to do so unless you simply have to unbend or re-align existing parts. Repair of the refill port, because it likely requires replacement of the gas storage tank, is also usually not cost-effective.
May 08, 2011 | Watches
I have a gold Dunhill lighter which belonged to my partner who passed away a few years ago. Whilst he was still alive I sent the lighter away to be cleaned etc, the shop I sent it through has now closed...
If you go to their web site http://www.dunhill.com/en-cn/catalogue/lighters/ at the bottom of the page you will see find a service center and find a store.
Click on one of these and you should be able to find the information you want.
Apr 04, 2011 | Dunhill Watches
My problem is that i can't find an postal or email address for somewhere reliable that i can send my old colibri 'molectric' cigarette lighter for repair. can anyone help? this lighter has great...
mcdevito75 here, Hello Dave, My advise is to take your lighter to a jewelery shop, you can try a small place, they may have the info or even repair your lighter. Also try Colibri watches.com try and see.
Feb 11, 2011 | Watches
I have a S T Dupont oblong face with gold glitter in, with croco veritable strap. Battery needs changing but none of the jewellers and jewellery hospitals can get the back off, if there a knack to it.
To remove the back, you must first remove the leather strap. Between the lugs on the case, you will find 2 small screws. Remove these and the back will come off with ease.
Jan 03, 2011 | S.T. Dupont Watches
Need a replacement crown for a st dupont watch model 155 F1 Bl07
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 11, 2010 | S.T. Dupont Watches
Dunhill cigarette lighter spare parts needed
Hi, Dan, I have 2 Dunhill ighters that work but they leak butane. Making them unfit for use. I would like to have them repaired/rebuilt. I believe they are 1960-70's vintage so, the lack of parts will definately be an issue here. Please advise. Thanks Glenn ghelfne1@nycap.rr.com
Jan 30, 2008 | Watches
Watches Logo
18 people viewed this question
Top S.T. Dupont Watches Experts
Ansel Alberto
Ansel Alberto
Are you a S.T. Dupont Watch Expert? Answer questions, earn points and help others
