Question about Ovens
Oven problem I have a creda solar plus modal 48906. The top oven is very slow to heat up. Any ideas, thanks aid
  • ams Jan 26, 2009
    thanks for your help. i have checked the grill element and thats working on full. switched the top oven on and within a few mins the bottom of the oven was to hot to touch. any ideas. many thanks
  • Anonymous Mar 24, 2014
    Slow to heat
  • Ovens Master
  • 3,463 Answers
Check that the solar plus grill element is working properly by selecting full grill, the whole element should heat up, if only half element heats up , then you need to fit a new grill element complete.
If the grill element is o/k , then it is possible the top oven base element is faulty, to check that is working, put top oven on and after a few minutews feel the base of the top oven, and it should be hot to the touch if it is not, then the base element has probably failed , and you will need to fit a new one.
These are the possible reasons for it to heat up slowly.
Plz rate my solution.
Thanks.
Posted on Jan 25, 2009
  • Barry Coates
    Barry Coates Jan 27, 2009
    I assume that you had had the top oven door closed when using it, if so and it is still slow to heat up, then the top \oven thermostat might not be sensing the correct temp, you need to check it with a thermometer.
    If o/k, then there is a overheat stat that may be operating prematurely, this could be the cause of the prob, and also check that the top top cooling fan is working, you should be able to hear it going.
    Hope these suggestions help.
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Creda oven manual
The heat control knob needs to be replaced. This controls the amount of electricity that foes to the burner. Sometimes the burner itself has too much resistance and will only work when full current is applied. Hope this helps, please post a comment that this is solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
May 10, 2014 | Ovens
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Dec 08, 2009 | Creda Ovens
Creda concept solar plus oven timer
Hold down the 2 left buttons together, and press the + or - button at the same time..
This should reset the timer.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Creda Ovens
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Ovens Logo
272 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you an Oven Expert? Answer questions, earn points and help others
