Question about Epson PowerLite Home Cinema 3020 LCD projector - 3D
Intermitant loss of picture
The picture is lost for a maximum of 5 seconds at random intervals.
  • 93 Answers
The problem looks like a mainboard problem if you have checked all the cable connections going from your source to the projector.If you are yet to confirm the cables, then u should try to check the connections by putting a spare VGA / video cable
Posted on Jan 18, 2013
Nikon f3hp shutter is getting stuck for random intervals of time
Water damage to the shutter speed dial, or poor contact in its flex connector, can cause this.
Nov 11, 2014 | Nikon F3HP 35mm SLR Camera
Random song shut down
if its a nsm then go into programme mode then p100 then 0 + h this disables all backgtound music
Apr 03, 2014 | Wurlitzer Jukebox CD Player
I have a Kodak M850 Easy Share hooked up to my television with an mini HDMI cable. The picture shows nicely but I don't know what camera button to use to make a slide show appear on the tv. Can you help?
Starting the slide show
  1. Press the Review button, then press the Menu button.
  2. Move autourg00422004id1197998.jpg to highlight Slide Show [img src="http://resources.kodak.com/support/jpg/en/manuals/GLB_en_urg_00422_images/autourg00422004ID1198002.jpg" alt="">, then press the OK button.
  3. Move autourg00422004id1198023.jpg to highlight your option, then press the OK button.
Mar 18, 2014 | Kodak Cameras
Sony drc-mf, 29inch turns on, red light brinks 5 times at intervals
29 inch Sony tv D R C good working but pip & Twoin pics no picture blank plz help me
Dec 26, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
How do you set the light delay, I lost my instruction booklet.
The 4½ minute interval can be changed to 1½, 2½ or 3½ minutes as follows: Press and hold the Lock button until the light blinks (about 10 seconds). A single blink indicates the the time is reset to 1½ minutes. Repeat the procedure and the light will blink twice, resetting the timer to 2½ minutes. Repeat again for a 3½ minute interval, etc., up to a maximum of 4 blinks and 4½ minutes.
Jan 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
How can you extend the time of the pulse from 5 sec to 60 sec on the mk111
On that model, the pulse is only adjustable up to 5 seconds. The pause between pulses can be adjusted to 60 seconds maximum.
There are 2 adjustment screws on the circuit board, A is the pulse time, B is the pause time.
Dec 02, 2010 | Velleman Interval Timer # MK 111
Random intervals,battery light somes on and a split second loss of power, but engine does not stall
make sure the battery connections are clean. Could be stopping the battery power. Either that or the battery needs changing.
Aug 05, 2010 | 1999 BMW 318 ti
Central locking went on my lexus took it the garage they said the key wouldn't reprogramme is there anything that can be done
Programming
When
Key added or replaced. System malfunction.
How
Driver's door open and key removed from ignition switch. Insert key into ignition switch, then remove it. Within 40 seconds: Press lock and unlock on the vehicle door lock control switch at 1 second intervals 5 times. Close and re-open driver's door. Within 40 seconds: Press lock and unlock on the vehicle door lock control switch at 1 second intervals 5 times. Insert key into ignition switch. Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes. Remove key from ignition switch. System should now lock and unlock vehicle, once or twice depending which mode has been selected. Within 40 seconds: Simultaneously press and hold key lock and unlock buttons for a maximum of 1,5 seconds. Within 3 seconds: Press any key button for a minimum of 1 second. System should now lock and unlock vehicle once.
Manufacturer: Lexus Model: IS 2,0 200 Engine code: 1G-FE Output: 114 (153) 6200 Tuned for: R-Cat Year: 1999-05
© Autodata Limited 2009 25/02/2010 V8.207M-ukad113581
NOTE: If system locks and unlocks vehicle twice, programming procedure has not been completed. Repeat programming procedure.
Within 40 seconds: If required repeat button procedure to program remaining keys.
NOTE: To exit programming mode: Close driver's door or insert ignition key. NOTE: A maximum of 4 keys can be programmed
Feb 25, 2010 | Lexus IS Cars & Trucks
TV turns off at random intervals.
99.9 % this problem comes when x'tal malfunctions just heat the x'tal of CPU and see if it works replace the x;tal.
Aug 07, 2009 | Sony KDF-E55A20 55 in. LCD Television
Powers off intermitantly
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Open Questions:
Epson PowerLite Home Cinema 3020 LCD projector - 3D Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
