Question about Royal VF1012mx Shredder
Overload works in reverse, auto will not work
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
Overload message on my janome 8000
I know you said you have performed the reset sequence, but try these steps and see if the unit goes through the diagnostics correctly.
  • Turn off your Janome MC8000. Wait for a few seconds.
  • Press and hold the "Start," "Reverse" and "Auto lock" buttons at the same time.
  • Release the three buttons once your Janome MC8000 turns on.
  • Locate the plus (+) sign on the machine screen. Press the plus sign when prompted. Wait till you receive a message that says "Test Complete."
5
  • Turn off the Janome MC8000. Wait for a few seconds.
6
  • Turn on the Janome MC8000 once again. This will prompt the embroidery machine to conduct a diagnosis. Wait till it finishes the diagnosis and troubleshoots the errors you were encountering before.
Nov 10, 2013 | Janome Memory Craft 5700
No power. Seems to be overloaded
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 25, 2013 | Office Depot Ativa DSD160D Shredder
Why doesn't OfficeMax OM99732 shredder work on Auto?
My shredder would not sense paper being inserted and the sensor could not be cleaned. So "Auto" no longer worked but the manual reverse DID work. I opened the thing up, reversed the polarity on the red and black wires on the connector for the main drive motor and VOILA!!! I can use my shredder in manual mode by switching it to REV. Be mindful that this keeps the motor running until it is switched off. This can heat the motor and cause failure so I limit my shredding to 60 seconds then give it a rest so it will cool down. Also there is no emergency reverse so watch your fingers and neck ties.
Dec 17, 2012 | Office Equipment & Supplies
How to check if Auto Reverse Works
Play a tape to the end. If it reverses, it is working properly.
Make sure that you have turned the auto-reverse feature on. The switch is next to the power button.
Jul 13, 2012 | Audio Players & Recorders
95 mustang v6 auto no forward gears but works in reverse had ****** rebuilt and same thing
Maybe your differential is shot and will only allow reverse spin or the transmission was not really rebuilt professionally. Was the transmission checked outside of your car after rebuild? Does your vehicle have a Powertrain Control Module (PCM)? Maybe the module went bad or faulty.
Jun 18, 2012 | Cars & Trucks
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Shredded a few sheets of paper. clicked off. Have power at outlet. No damage to cord or connections. No auto reset of internal overload protection, amount of paper shredded far too few to trip...
Hi, make sure the cutters are not jammed with paper. To reset turn the unit to reverse for 2 seconds then auto then off. Allow to cool for 25 minutes then retry. Also make sure the base is locked in properly. Hope this helps, regards Phil.
Jul 08, 2011 | Fellowes Office Equipment & Supplies
Royal VF1012mx Shredder Logo
29 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
