I've a problem in my VGA video card in my computer
  • 3 more comments
  • ponmy2006 Jan 25, 2009
    My graphics card's disc was corrupted
  • ponmy2006 Jan 27, 2009
    Graphics card is ATI and os is win xp
    Yes, I'm looking for drivers to reinstall you graphics card
  • Azz
    Azz May 11, 2010
    What graphics card are you using and what operating system?
  • Gary Schellhas May 11, 2010
    Are you looking for drivers to reinstall you graphics card?
    can you please explain further?? We need more information to complete your question.
  • 55 Answers
Hi, go to the ATI website here:-
http://ati.amd.com/support/driver.html
Select your OS, what product family it belongs to and then select the actual model, press go and you will find the drivers you need.
Hope this helps.
Posted on Jan 27, 2009
  • 112 Answers
Check all cable, try another vga card to run it.
Posted on Jan 26, 2009
After installing new ATI HD4670 video card on my Gateway zx6810 I boot system hear no beeps computer powers on but screen is black
Hello
Is this new video card the only video source on the PC (i.e. there is no other VGA connections on the PC)?
Without knowing the make and model of the PC, I will list the most common issue when replacing the video card in a PC.
1. Connect the monitor to each available VGA connection and boot the computer - to see if any VGA output is working
2. When you find a working VGA output, go into BIOS and change the VIDEO settings to either allow BOTH the onboard and add in video OR allow the add in video only. Save the changes and turn the computer off.
3. Move the video cable to the add in video card, turn the computer on and see if the BIOS is using the new Video card
Nov 03, 2013 | Sapphire ATI RADEON HD 4670, (1 GB) PCI...
How to fix a no signal monitor ?
If you have a known-good video card and a known-good VGA cable connected, another possibility is that the monitor is defective
Jan 15, 2013 | Dell Dimension C521 PC Desktop
How do i get my asus model ul80j to switch from integrated graphics to nvidia
From my years of working with computers most of them only work with one video card at a time. If you have two video cards on the computer and if you have them both connected, a lot of computers get confused and can't handle that.
I've seen computers where there is a VGA Port (that normally comes with most computers) and the user goes out an purchases some heavy duty graphics video card and installs it. When they try use the VGA port, the computer refuses to switch to it as long as that other video card that they purchased is in the computer.
I've down countless of house calls to repair a computer where the purchased video card has gone bad and the customer thinks they are up the creek without a paddle until they get a new video card. Not so, I just remove the bad video card and plug into the vga video port that came with the computer.
Mar 30, 2012 | ASUS UL80JT-A2 Notebook
Need abetter graphic card for acer aspire 5251
in Acer Aspire Series is using Intergrated Graphic Card.
that mean if you wanna Upgrade your Graphic Resolution,
you have to set to a bigger shared memory/RAM for Display Graphic Card/VGA memory from BIOS Setup.
for example if you using RAM 2Gb, and you can make your VGA(Video Graphic Adapter) to 1Gb.
But in My Computer Properties the RAM will Show only 1Gb.
Because another 1Gb of RAM you've use for VGA.
you can check it from dxdiag.
(for opening dxdiag > Click Start > click RUN... > type dxdiag > and Oke/Enter)
Jan 07, 2012 | Acer Computers & Internet
I want the definition VGA card
A "VGA Card" would more commonly be called a Video card or Graphics card. This is what sends the video to your computer monitor. VGA is the name of the type of plug that the card uses to plug into the monitor. Video cards use VGA, DVI and HDMI for higher quality Video cards.
Thanks for using FixYa.
Aug 20, 2011 | Computers & Internet
A compaq sr1000 need to know what no VGA input means. Will no allow my computer to come on
Welcome to FixYa
No VGA input means that the computer is not detecting video input from the video card. Usually you get this message if the video card of your system is not functional, the VGA cable is unplugged or the VGA cable is defective. To try and remedy this problem try these.
Check if you can hear sound coming from the system. If the video card is functioning then you should here the startup audio from windows.
Check the VGA connection on the back of the system. The VGA cable looks like thismalups_6.jpg
Please note that the VGA cable has two screws, make sure that both are fastened correctly
If the VGA cable is plugged in and you cant hear audio coming from the system. Then this would likely be caused by a defective video card on your computer
Hope this helps
May 28, 2011 | Compaq Computers & Internet
Vga driver
> VGA DRIVER
VGA ==> Video Graphics Adapter
DRIVER ==> device-driver software to allow Windows to use the device
So, what manufacturer of video-card?
What model of video-card?
What Operating System are you using? XP? Vista?
To find the correct device-driver software, the above 3 questions need to be answered.
Have you looked on the "support" web-site for the manufacturer of the hardware?
May 08, 2011 | Computers & Internet
How i can connect the tv as my computer moniter
Does your TV have a "VGA" input? If so, then connect the VGA-output from your computer's video-card to that VGA-input.
Does your TV have a "DVI" input? If so, then connect the DVI-output from your computer's video-card to that DVI-input.
Does your TV have a "S-Video" input? If so, then connect the S-VIdeo-output from your computer's video-card to that S-Video-input.
Note that only _SOME_ video-cards have DVI output or S-Video output. Check your video-card.
Dec 01, 2010 | Computers & Internet
Games lock up on strange screen
hi there,
well if you' ve seen frequent flickering in your screen this is the sign of there's problem on your video card and sometimes at the middle of game or doing work at computer you will be hang,try to clean your video card it could be keep your screen smooth and recover the quality of graphics,how to clean your video card, unplug power supply unit, open your pc cover,disconnect vga cable from video card,pull out your video card,scrub the multi slotted terminal by eraser head of pencil both side,then put it back video card and vga connection,if the screen has good quality after cleaning and persist again the symton of flickering,replace your video card.have a nice day,rate my fix,thank a lot.
May 14, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
