Question about Intel Motherboard
Connecting i brought new mother board , but i don't how do to connect jumper setting ? LED. power switch ?
  • 21 Answers
Marked on the motherboard are abbreviations for those connections ie. PWR SW, additionally your included user manual should specifically detail the installation process... if this still seems to much for you, perhaps you should not risk damaging the system further and seek assistance from a (bricks and mortar) PC store and/or technician.
Posted on Jan 25, 2009
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Thanks.
Aug 22, 2013 | Gateway Computers & Internet
Thoshi satellite L40 bios password reset
open *********** board battery some time or " mother board battery
inside 3pin jumper switch. open this jumper middle pin to other pin connect some time 1 minute & jumper set previous position.
or" see mother board battery
inside reset switch.
May 28, 2012 | Toshiba Satellite A105-S2071 Notebook...
HP G61 no power
inside reset switch
May 28, 2012 | HEWLETT-PACKARD G61-306NR Notebook
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
ASUS LGA775 mother board
1.Power down your PC.
2.Locate a rocker-style switch at the back of your PC (if applicable), and switch it from the on position (I) to the off position (O).
3.Find the 3-pin jumper near the power supply, typically labeled "clear cmos" or "reset bios".
4.Remove the jumper from the default position (typically connecting the 1st and 2nd pins).
5.Replace the jumper to connect the 2nd and 3rd pins.
6.Push the power button on the front of your PC once.
7.Wait a minute.
8.Return the jumper to its default position, connecting the 1st and 2nd pins.
9.Move the rocker-style switch at the back of your PC (if applicable), to the on (I) position.
10.Power on your PC with its front power button.
If it doesn't work go to alternate options
Alternate Method
1.Locate a rocker-style switch at the back of your PC (if applicable), and switch it from the on position (I) to the off position (O).
2.Remove the CMOS battery. This should be a regular 3V, round, flat watch battery.
3.Wait at least 5 minutes.
4.Reinsert the CMOS battery.
5.Move the rocker-style switch at the back of your PC (if applicable), to the on (I) position.
6.Power on your PC with its front power button.
Alternate Method
1.Turn on your computer and press the key on your keyboard to enter the BIOS. This is typically the Del (delete) key. Pre-built systems from major manufacturers may use a function key such as F1, F2, or F10.
2.Go to the last tab or page of your BIOS.
3.Select an option similar to "restore factory settings".
4.Save your changes and confirm your selection if necessary. This will often be combined with the process of exiting a BIOS. Some BIOS types may have this as a separate option such as "F10: Save Changes".
Nov 21, 2009 | Computers & Internet
No Boot , new P5QL-EM mother board
Check the heat sink ontop of your cpu sounds like bad connection and it will cause it to do as you describe
Aug 04, 2009 | ASUS P5QL-EM - Motherboard - micro ATX -...
Wiring a P4M80-M4 mother board
You can download the manual for the motherboard here, just click on the "manual" link:
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=246
This will list the front panel connections, which are 2 pins. Each of the jumpers, what you are calling clips, will connect two of the pins. Most cases have the jumpers labeled, i.e. power, reset, etc. But if they are not, it is usually: red/white = HDD led; green/white = power led; red/black = speaker; black/green = power switch; and black/white = reset. But your case may use a different wiring spec, but should list somewhere which wire is for which function.
Feb 28, 2008 | Computers & Internet
K8 Neo-2 V-2.0
Please connect jPw1 to 4 Pin 12v, this supplies power to CPU. Than enter Bios & find Boot settings. Set the cdrom as boot 1 & hd as boot 2. Check the jumper on the cdrom, as it is the only device on secondary IDE controller it should be set as a master.
It is better to install a fresh copy of windows with a new motherboard. Put your windows CD in the cdrom & the system will boot to it. And your on your way. You can install the drivers for the board after windows has been installed.
Enjoy!
Plaease vote..
Dec 05, 2007 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Compaq for Evo D300 Motherboard
The manual can be found here. There is a numbered diagram inside. http://www.eserviceinfo.com/downloadsm/5105/Compaq_Evo%20300-500.html Hack
Jul 09, 2007 | Compaq (281946-001) for Evo D300...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
