Question about Dewalt D24000S Wet Saw With Stand
Wet saw does not cut at right angle to carriage on dewalt 2400
Is there any adjustment to rails
  • 2,176 Answers
Go to Dewaltservicenet.com and in the middle of the page at the bottom type in your tool number. On the next page click on the right side under manual. The manual is 42 pages long but it does have the information you need to readjust this saw. Let me know if you need any more help
Posted on Jan 25, 2009
  • pkilwy Sep 09, 2010
    I have two questions:
    Only the center wheel touches the right rail. Is this normal for this saw? When I loosen the center wheel, the front and rear ride normally on rail. Seems the center wheel is too low.
    My blade does not track in the center of the cart slot. It rides very close to the left side of slot. Can this be adjusted?
  • David Ford
    David Ford Sep 09, 2010
    make sure all the flanges and spacers are in place and the flanges are installed properly
I have recently bought a B and D Deluxe Power Shop radial arm saw, but without a manual. I cant find how to adjust the angle of cut. my old dewalt was simple but I cant find the adjustment on this one
Should be able to find manual on line---put in make---model number in address bar (search engine Google) and you'll all types of info---GL
Jan 21, 2017 | Dewalt Saws
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
Fixing bad motors in dewalt angle grinders power tools
it would be much better if you bought a new one because it would be cheaper
Jul 04, 2014 | Dewalt DW824 5" Electric Angle Grinder
How do i adjust the alignment of blade on Dewalt wet saw
That's easy to do it , all you have to do is lose three screws on the left side of the track. There are four screws, on each track, you have to start from the front to the back. Don't lose the Last one. The four one. Then there's one screw under of the rails. going horizontal. It's going to be in your left side. You have to do is just screw in. Ifyou want to open it. Screw it out if you want to close it.
Sep 29, 2012 | Dewalt D24000S HeavyDuty 10inch Wet Tile...
How do you lower and raise the blade on my d364 circular saw
There are typically two adjustments on the saw, both of which operate with a wingnut type of screw/bolt. The one in the front of the saw adjusts the angle of the blade (typically front right hand side of saw) and the second, to the rear right hand side of the blade, adjusts the depth of cut by moving the bed (flat part of the saw on the bottom) up or down.
Jun 20, 2011 | Dewalt Saws
I have an outside corner cut with a 45 degree slant and cannot figure out what my angle should be to get the right outside miter cut
You can solve this with geometry, but it will take forever and your answer will only be approximate (due partly to the limits of accuracy of the scales on your saw). If you are using a table saw, use scraps of wood and trial and error. It takes a while, but you can get a perfect result. If you are using a miter saw, then support your work from underneath at the angle to match your situation, and simply cut at 45 degrees.
Aug 31, 2010 | Dewalt DW744S 10" Portable Table Saw with...
How do you cut angles on this saw. It was given to me and I can figure out everything else but cutting angles. Thanks
When you are facing the front of the table saw. Right above the Dewalt logo, there is a hand wheel that if you crank clockwise - it will tilt your table saw blade to the angle shown where the hand wheel is.
May 12, 2010 | Dewalt DW746X 10" woodworker's table saw...
Blade does not cut straigt. How do I adjust the
There shoul be a scale and a crank or screw used to adjust the blade angle on the front of the saw blade feed bushing. Make sure you set this to 90
Feb 26, 2010 | Dewalt & Variable Scroll Saw
My saw cuts at angle to the right
When My Pioneer did that a close inspection found a wire edge on the top rear and bottom front rails of the bar. A flat file used at 45° to the rail removed it. The bar once again cuts true. The only other likely possibility is the chain is sharpened at different angles. HTH
Lou
Dec 04, 2009 | Homelite ZR10926 16 Chain Saw
Cannot rotate the Dewalt 708 mod 3 saw horizontally
If you have loosened the handle a little and pulling the adjustment trigger didn't allow for movement,you may need to remove and clean the turn table.(don't forget,the handle must be loosened for the turn table to rotate)
Please rate this a fixya
Feb 09, 2009 | Cross Dewalt& 12" Double-Bevel Compound...
Dewalt D24000S Wet Saw With Stand Logo
497 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
