Question about Beam Q power Brush Q100
My beam Q100 power brush starts for about 5 seconds then stops power.
When I turn it on it runs and vacuums for about 5 seconds and then the power fades and the red light goes on resulting in no suction or movement of the roller.
    President:
  • 2,976 Answers
Take the brush out and check for hair & string around the ends where it goes into the bearings. Remove the crud and reassemble. NEVER oil the bearings. It will collect dirt and dust and gum up.
Posted on Jan 18, 2013
Testimonial: "Once I figured out how to open the housing to the power brush (it was tight and difficult), I found an amazing amount of hair and crud. Removal of this resulted in the normal operation of the power brush. Thank you!"
Roller brushes won't work
Remember, this brush is belt-driven (not air-driven), so if the brush stops working, then there is probably a problem with the belt. The device is likely set to stop the brush from spinning if the belt tension is not correct. My guess is that the belts have become too loose, or there is a malfunction with the sensory mechanism which detects that.
I will trust that your product does have the in-house warranty.
May 19, 2014 | Shark Navigator Bagless Upright Vacuum
We have a Beam Q100 power brush and the fuse repeatedly blows. The Outage for the socket is okay.
Regardless of the vac shops analysis you do have a problem with the power head. It may be an intermittent problem that only happens when not at the shop. Ask the shop if you can test drive a new head at your home. Offer to leave a deposit on the new power head while you test your system.
Jan 09, 2014 | Beam Q power Brush Q100
Broken handle release pedal
Definitely. Just find your local authorized BEAM dealer and they will sort it for you. Sorry, I don't know where you are so I can't find you a dealer but BEAM's website has a dealer locator.
Dec 24, 2013 | Beam Q power Brush Q100
Power head brush wont run
Could have a loos belt, check and replace if necessary.
Nov 23, 2013 | Vacuums
DC 17 UPRIGHT BRUSH MOTOR WONT STAY RUNNING. TURN
have a look at the filters first as it sounds like you blokeage
Oct 31, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kenmore 116.23513301
If the motor on the power brush is running the belt is bad, if the motor on the power brush only runs when you push the overload, the overload is bad.
Sep 14, 2009 | Kenmore 22812 Bagged Canister Vacuum
I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
Generic problem for all Vacuums
I have a one year
posted by jon89 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Beam Q power Brush Q100 Logo
234 people viewed this question
Top Beam Vacuums Experts
cazo06
Level 1 Expert
Beamvacman
Level 1 Expert
Thatvacguy.com
Are you a Beam Vacuum Expert? Answer questions, earn points and help others
