Question about LG 60PC1D 60 in. Plasma Television
Lg 60PC1D my picture looks like a negitive. there is still some color and the but there is no sharpness and the picture is dark and grainy.
The picture was fine one minute. I walked out of the room and came back in to find a very dark and grainy picture. The change was immediate and dramatic.
  • 3 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
  • 13 Answers
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Posted on Apr 28, 2009
SOURCE: Picture dims dramatically
I have the same problem so far the best I could do was to put the user setting to sports and brighten up the tv as much possible without making the picture look too bad. Good Luck
Posted on Feb 25, 2010
freelance-au
  • 131 Answers
SOURCE: 61" plasam TV will not turn on
This is one of two problems, Bad capacitors in the power supply or your Y Sustain board has failed, I would go for the first, take the back off your tv and look for swollen or domed shaped capacitors on the power supply, They may also leak a brown liquid like substance.
Replace all that you can see and this should cure the fault.
Posted on Mar 05, 2010
freelance-au
  • 131 Answers
SOURCE: LG 60PC1D making clicking sounds
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Please rate my reply ++++
Posted on Apr 05, 2010
Do older tv's lose their color and sharpness 50" toshiba or is it the cable reception that is dark & grainy.
If we are speaking of a CRT, sure, a rear projection device, yes the bulb and mirror system picks of dirt, moisture, smoke, nicotine and the lot. If this is a new flat screen, yes the rear or back light system does lose its ability to produce a pleasant picture.
Good Luck
Mar 16, 2015 | Sharp Televison & Video
Fixing the picture in my Philips rear projection tv
As far as mostly red--turn color to zero and examine screen--if not gray or black and white it may need the screen controls adjusted.
Dark---with back cover off clean the three lens this model has--they are the light source for your picture and if dusty picture will be darker and somewhat dull looking.
Answer is based on brand/model number listed here.
May 16, 2012 | Philips 50P8341 50" Rear Projection...
Heard a pop noise from LG 60PC1D tv, tv shut off and now the picture looks like a negative kind of...what is wrong?
Capacitor on the power supply popped and it is not allowing the proper voltage to be reached to the main board. This is messing up your picture. I would repair it before you create more damage from the blown capacitor on the power supply.
Please rate if this helped :)
Mar 08, 2011 | LG 60PC1D 60 in. Plasma Television
What do the capacitors look like in the LG 60PC1D 60 in plasma TVs? is there a picture? I am having a problem with tv not starting. i have the back panel off the TV. I see some coils that look to have...
please be very careful with capacitors - they can retain their charge long after the power has been switched off and can deliver nasty (even fatal) shocks.
They look like little oil drums and are located on the mother board.
Feb 04, 2011 | LG 60PC1D 60 in. Plasma Television
The dark color of my tv was change unspected the dark color now are blue, violet,and other exept black, the dark scense can't see. please help me.
I believe you either have a bad LCD Controller Board or a bad Main Board. The only way to know is to replace one. If it doesn't fix it , replace the other. Or replace both and it should be fixed.
I hope this helps,
Skyassoc
Nov 03, 2009 | Sharp LC-42D43U 42 in. LCD HDTV
No real color picture, looks like an undeveloped negative, ghost
The pictures are indeed negative.  When scanning negatives or transparencies make sure you have the scanner set to the appropriate setting, otherwise simply Invert the colors in Photoshop, or similar photo editing software.
Dec 03, 2008 | Cameras
Blurry pics indoors
1. you could try it with flash, but the lighting in the picture would look artificial, won?t reflect the interior of the building as it really is, and the flash will cover only near objects leaving the rest dark, and we?ll be missing the point. 2. recommended ? place the camera on a stable platform(table, chair, shelf etc in lack of a tripod), adjust its vertical angle by placing some flat object under the front side of the camera, set it to auto or a preference to slow shutter speed(usually 1/60 to 0.5 of a sec according to the lighting), set timer(most cameras only give you about 2 seconds) in order to avoid vibrations during the picture taking. 3. you should avoid using more then 50 to 100 ISO, more will give you a grainy effect. You are promised a sharp picture with life like colors that looks real.
Feb 21, 2006 | MitekMedia CD30P3 Digital Camera
LG 60PC1D 60 in. Plasma Television Logo
Computer Repairing
Computer Repairing
