Question about Acer AC 713 17" CRT Monitor
Flashing monitor hi all, i have an ACER AC713 (17") monitor which has been functioning satisfactorily for the last 3 years. but today when i switched on the PC, the monitor started flashing the images with time period of 1-2 s. i then removed the two speakers which were kept near it. although the flashing continued for some more time, the picture eventually stabilised after about 20 minutes or so. my ram had gone bad yesterday and had to replace it. so im woried whether the present problem is also related to some circuitry or power module. kindly advise.
    President:
  • 2,961 Answers
The ram itself is not related to your problem, but check the VGA lead connections at both ends and see if the connection is loose and also check the power cable. Other than that it may be the monitor circuitry or CRT itself thats the problem and after warming up the problem goes away, so a repair may be needed or a replacement monitor.
Posted on Jul 13, 2007
How to program the time Warner remote
hi,
To manually set up the remote to operate a device, find the manufacturer code of the device in the list of manufacturers' codes. The codes are logically grouped by device type in section 12. Once you find the code, performe the following:
1. Press and hold the device key until all device keys begin to flash (approximately 3 seconds). Release the key. The selected device key will continue to flash.
2. Enter the four digit code for the desired device using the number keys. After pressing the first digit, the device key whould light and remain on. After the last digit is pressed the device key should flash three times and
3. Test the code by trying various functions. If the primary function keys fail to respond satisfactorily try the next code listed for the manufacturer.
If its didn't work go to the bellow added link. Select you remote. then add you device and its brand to know its code and programming procedure
http://www.timewarnercable.com/en/support/program-your-remote.html
www.electro-medical.blogspot.com
Sep 14, 2015 | Televison & Video
My acer al2216w screen flashes black and white every few seconds. power light is on with no flashing
hi. check out put voltage of supply board. if it was correct check inverter and lamps.
Apr 26, 2015 | Acer AL2216W LCD Monitor
Acer monitor will not start, power button flashes
hi Samuel.
this is all i could find from the internet.
You can try a power reset to see if that helps. To do a power reset, unplug the power cable and press and hold the power key for 10 seconds. Then, release the power key and plug the monitor in and attempt to use it. If you are still unable to get a proper display, We would suggest contacting technical support to inquire about warranty repair options. Many of our monitors carry a 3 year warranty, so there is a chance you may still have warranty left.
Acer Service and Support
you could also try this link out.
Acer 22 X223w LCD Monitor will not start up Google Search
Dec 14, 2017 | Acer 22" X223w LCD Monitor
When I boot up my computer, it takes my Acer monitor 20 minutes to show the desktop. It flashes the Acer logo, then goes black, then flashes again, and repeats till it finally comes on. Could it be a...
It's probally the inverter board that drives the backlight in your monitor is failing causing the digital board to reset. I think Acer has a 3 yr warranty. If the monitor is less than 3 years, I would call them and ask them to repair it. They will fix it for free if it less than 3 yrs old, it will only cost to you is shipping it to TX. Hope this helps.
Aug 06, 2010 | Acer AL2416WBSD 24" Monitor
I have two Acer monitors that the on/off keeps flashing and nothing comes up on the screen. I don't think I will buy another one. I tried to save money and have only had these two monitors for less than...
Acer has a 3 year coverage on the LCD Monitors.
I have seen this before the power supply inside the screen has went bad.
I would contact Acer Support 1-800-816-2237.
You will have to pay for shipping just so you know.
I hope this helps please let me know..
- Jon
Aug 22, 2009 | Acer AL1916W 19" LCD Monitor
No signal from monitor
when u power up the computer pressF8 key then enter in enable vga mode.
then if u r able to enter in there then change screen resolution.
And if u r not able to enter then check cabel from computer to monitor .
Also refix ram on cpu.
let emknow mt email id is "computerrepair@yahoo.co.in"
Apr 18, 2009 | Acer AL1916W 19" LCD Monitor
Monitor Problems
It has a 3 year warranty.
Mar 15, 2009 | Acer P221W LCD Monitor
Faulty monitor after one year
Hi Shirley,
In Singapore, Acer monitor is 3 years warranty.
If the your monitor is out-of-warranty, please consider replacing. It is cheaper than repair.
Performance life is normally around 2.5 yrs ++. Normal faults is due to manufacturing defects.
Dec 30, 2008 | Acer AL1916W 19" LCD Monitor
Acer AC 713 17" CRT Monitor Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
