Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven will not turn on
When I press the start button to pre-heat it does nothing
The oven wont come on when I press start. It clicks but never ignites.
Posted on Feb 01, 2009
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
I dont no how to pre heat the oven
To pre-heat an oven is to simply turn it on to the desired temperature and wait 5 to 10 minutes. If you have a timer then set the timer for the desired time you want to pre-heat then begin baking as usual.
There is no magic to pre-heating an oven and everyone that bakes has a different opinion.
Sep 23, 2010 | Ovens
Frigidaire gas oven, 5 years old, oven pre-heat light comes on and stays on, oven gets warm but not up to temp (it was like this for about an hour), also smell gas when oven door is opened. Burners work...
I don't have a solution, but I was wondering if it constantly beeps until you press the start button? I am having the same problem with my oven preheating. Until we can figure out how to stop this we unplug it and shut the gas off when not in use.
Aug 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't pre-heat
This is a failed oven temp sensor. the control is not receiving a proper resistance signal from this sensor at this time. the control will shut down the unit if this is the issue. check the oven temp sensors connections form the control to the sensor housing for loose or worn contacts, if the wiring is ok, replace the temp sensor.
Sep 24, 2009 | Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Oven won't heat.
EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
Dec 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
167 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
