Question about Proform 650 Crosstrainer Treadmill
Blue screen the treadmill works fine, the screen is blue and so we can't monitor progress, etc.
Hi, I have a motorized treadmill JX-260E & it just won't start. It worked fine until yesterday, now when I turn it on it beeps & reads ERROR 9 on the screen. I don't know what this m
Hi sir.
After reading his problem.
Please do the Maintenance and LUBE,
The error # 9 mean that thinking.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
How To Lubricate Treadmill
Nov 24, 2017 | Exercise & Fitness
The treadmill on my Roger Black Gold Treadmill won't move when the power is on. The board lights up and the incline etc works but the treadmill just won't move. Can anyone help me please?
please see the video and proceed according, LUBE the rollers bearing very IMPORTANT!
However , if the problem persist your must test a) main motor+belt
b) main control motor board see the block diagram attached.
God bless you
Jan 04, 2013 | Exercise & Fitness
Front console not working
Try this first: 1) Replace the batteries by new ones, clean the contacts batteries very well with c. cleaners.
2) adjust the REED swtich, test for open or faulty, clean it, and tigh the connector very well.
3) tight the ribbon cables inside, clean it, and tight very w.
4) see the diagram attached and try again.
God bless you
Dec 10, 2012 | Nordic Track NordicTrack T7 si Treadmill
Image 17.5s walking belt doesn't work automatically
your information is NOT clear however, you must adjust the REED swtich, see the diagram, clean it, and tight the plug very well
2) RUN the software calibration, for diagnostic, troubleshooting, and fix it.
3) LUBE THE deck belt inmediately, maybe you have a worn deck belt, time to replace it.
God bless you
Oct 14, 2012 | Icon Image 17.5 S Treadmill
Help, my Asus Essentio CG5290 won't post after moving.
check the cable for the bad monitor at BOTH ends. Some cables detach from BOTH ends, and if one side is lose, then you will get weird stuff happening....odd colors, lines etc.
Otherwise...it would seem to be a bad cable....which would **** if it is one of those that does NOT detach from both ends.....since you can't just go get another monitor cable.
Tallon41
Sep 16, 2012 | ASUS Essentio Computers & Internet
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
I have a 22" Westinghouse
Change the settings on your HDMI output to 720 progressive for resolution. The tv likely cannot handle the 1080 resolution, or the tv can only use interlaced (1080i or 720i) format.
Aug 21, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
My sceptre X22WG is no longer showing white screen but getting progressively darker blue. How can I get it back to a white screen?
Colour changes like this are either due to a failing graphics card, failing monitor or bad connection from the computer to the monitor.. with this monitor, I'd have it checked by a tv repairman
Jan 18, 2011 | Sceptre x22wg Gamer Monitor
Does the odor treadmill measure heart rate without holding on to the grips
Are you sure you have the correct brand of Treadmill. Never heard of this one.
Double check your brand and model. IFIT is availalable on several brands and models of treadmills, it is possible that your treadmill only has heart rate grips and also possible it will do both.
Generally a treadmill that will work with a heart rate strap will say so right on the face.
Dec 05, 2010 | Heart Interface Ifit Treadmill My Progress...
Cannot turn off progressive scan mode on blue screen to play dvd
If you have not already seen this or done it - it worked for us:
On page 18 of the user manual under Progressive scan there is a Caution which says - If you set Progressive Scan to On in error, you must reset the unit. 1) Remove any disc from the unit and close the disc tray. See that "dISC " is displayed on the display window. 2) Press STOP (9) and hold it for more than five seconds before releasing it. The video output will be restored to the standard setting and a picture once again be visible on a conventional analog TV or monitor.
May 20, 2009 | Zenith XBV442 DVD Player/VCR
Proform 650 Crosstrainer Treadmill Logo
19 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
