Question about Philips 20DV6942 20 in. TV/DVD Combo
Have just purchased a Murphys "26" widescreen lcd tv with freeview and DVD combi. I mounted it on wall bracket then plugged it in and blew the fuse in plug. There was also smoke coming from top of TV. Tried everything different cables still nothing worked. Reported this to where I purchased it from and they sent out a replacement. I Mounted new TV and used power cable from my computer and TV worked fine. I took the original cable that came with the TV and replaced the fuse in it with a 3 amp which was the same as what was in it. When I replaced the cables and switched the TV on it blew again. I have since been given another replacement TV and cable but I am very unsure of what might be causing this problem to happen have you any idea?. The new cable sent has also a 3 amp fuse in it, which has blown twice already, where as the computer cable has a 13 amp fused and worked fine. Would it do any harm to place a 13 amp fuse in the cable rather than a 3 amp?
New cable as the other one was faulty.
Posted on Jan 26, 2009
What weight is this TV? I'm wanting to get a TV wall bracket so I can put this on to the wall. As this is an old TV and has no Freeview is there a way of connecting/getting Freeview to work
Yes there is a way buy a freeview box with a legacy scart plug connect to TV with a scart lead and use the freeview box remote to change the channel on the decoder and have the av input for the decoder on the TV and use the TV as a monitor only
as to the weight and how to mount the TV type and model would be helpful
Jan 22, 2017 | Televison & Video
How do i get a replacement for my Emerson 26" LCD HDTV DVD/COMBO fell and dented from the stand. My warranty started in Jan. 03, 2014
Not sure whether you can get replacement under warranty if the TV fell off and was damaged. If it was wall mounted and the bracket broke or collapsed you could claim from the bracket supplier or the installer. But if it was on a stand sitting on a table and was knocked down then there is not much that can be done.
Best to call the place from where you purchased the TV and ask what they say.
Aug 27, 2014 | Televison & Video
What type of wall mount bracket will I need
Depending on what you want, Just make sure it is made to hold at least a 32 inch LCD TV . If you would like to tilt it, buy a tilt mount. It needs to be mounted to the studs in the wall for best support. I recommend you pre wire the cables before hanging the TV,since they will be hard to get to after the set is mounted.
Aug 07, 2014 | iSymphony 32" LC32iH62 LCD Widescreen...
I have a hitachi 26ld660c tv that is wall mounted, I need to purchase the table mounts and stand can you help
If you live here in the Philippines, visit CDRKing they have wall mount gadgets. or try on Ebay for any other option of wall mounted bracket.
Sep 23, 2011 | Hitachi 26LD6600 26 in. HD-Ready LCD...
How do you mount this tv on the wall? Jim
Visit the manufacture site for your TV. Look up the model number. Look at the accessories. See if they have a wall bracket kit available.
For some models you can buy a universal bracket. It's best to order the original.
Jerry G.
Jan 19, 2010 | Toshiba 26LV47 26 in. LCD TV/DVD Combo
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
Looking for wall mount for MLTD2622 26" tv
I had similiar issue with 32 inch...bracket required an adapter which I found through Best Buy. Check out Sanus.com They should give you discription of what you need and tell you where to get it. Adapter was very cheap ($19.00 or so). It is essentially two metal bars that bolt to regular wall mount, the bars will line up with bolt holes on TV.
Dec 13, 2008 | Memorex MLTD2622 26 in. LCD TV
Attaching 26 " lcd to stud wall
12 inches is the minimum for mounting the unit to the wall. I mounted a 42 inch LCD using a Sanus tilt (non-swivel) mount from Best Buy. We mounted it on wooden beams exactly 12 inches apart. Works great!
Mar 05, 2008 | Televison & Video
TELEVISION
This user manual should help!
http://portablemedia.manualsonline.com/manuals/mfg/wharfedale_international/l15t11wa_l15t11wc_l19t11wa_l19t11wc_l20t11wa_l20t11wc_l19t12wa_l19t12wc_l20t12wa_l20t12wc_l22t11wa_l22t11wc.html
Jan 13, 2008 | Televison & Video
Philips 20DV6942 20 in. TV/DVD Combo Logo
163 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
