Oce plotwave 300 error 12535
Error 12535
SOURCE: OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Posted on Aug 31, 2009
  • 990 Answers
SOURCE: Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Posted on Oct 10, 2009
SOURCE: what is a error m1104 on my Oce 31x 5e
From what I gather from Oce' this is a "Master Cylinder Error". It's an internal issue that a tech needs to come out repair. Attempting the repair yourself (if you are looking at doing it yourself) will actually void your service contract with them.
Posted on Aug 20, 2010
SOURCE: oce plotwave 300 error 8513
Dear Sunilkudal20,
the error code referes to an electronic failure in the fuser section.
  • You can try to reset the system by turn the machine off and on.
  • Check if there is no media is in the fuser section.
If this is not solving the issue, I advice you to contact you local service organization.
If you leave your country of origin, email adress and / or your telephone number, I can ask a colleque to contact you.
Kind regards,
Jack de Weirdt
Oce Technologies B.V.
The Netherlands
Posted on Aug 01, 2011
rsatishniki9
SOURCE: oce plotwave 300 error maintenance
Error Code 15709 is coming frequently... what should i do for this? please do the needful...
Posted on May 24, 2012
Oce Plotwave 345 with error codes 22514,22553,8532 can't find a service manual for this
There is nothing you can do, even if you had the service manual. The first two error codes deal with power supply issues and the last one deals with the fuser section, which may be related to the initial problem of power issues. I would recommend you call an authorized Oce/Canon service representative to determine what exactly the fault is. This printer is a new model, and there is not likely parts available outside of official Oce/Canon logistics.
May 22, 2017 | OCE Office Equipment & Supplies
Hi i have a problem with oce plotwave 360 give me an error 22552 we change the sd card but still have the error
Hi i have a problem with oce plotwave 360 give me an error (NO COMMUNICATION WITH CONTROLLER - 95) please help me wath i need do
Apr 19, 2015 | Office Equipment & Supplies
I have an Oce Plotwave 300 giving 22529 errors. Have replaced the spider board and usb cables. Any suggestions ?
Clean the paper tray, rollers, and clear any jams. The OCE Plotwave, being a large scale printer (used for posters and the like) is prone to jams and gumming up of the rollers. The error occurs when the paper doesn't move along properly and the sensors that read the surface and adjust the paper can't get it to adjust. Other issues can cause the same generic error. This includes incorrect PIN settings on the mainboard (some of these printers have PIN controllers that determine if it will read a certain way). It could be a read/write error in the USB control board (check to make sure all ribbons are correctly seated and all connections are making proper contact and are in the right ports). I suggest trying the OCE cleaning tool to see if that helps. Oc PlotWave 300.
Jul 31, 2014 | Oc Plotwave 300 Developer
Oce plotwave 300
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
May 03, 2013 | Office Equipment & Supplies
OCE PLOTWAVE 300 ERROR CODE 8510
JAI UN PROBLEME AU PLOTWAVE 300 MARQUE OCE
CODE ERREUR 8510
C QUOI LE PROBLEME ET C DU A QUOI ET QUESQUE JE DOIT CHANGER
MERCI
REPONDEZ PAR EMAIL
benztirage@yahoo.fr
Jun 27, 2012 | Office Equipment & Supplies
Oce plotwave 300 error 8513
Dear Sunilkudal20,
Kind regards,
Jack de Weirdt
The Netherlands
Jul 26, 2011 | Office Equipment & Supplies
Oce plotwave 300 error maintenance and troubleshooting manual
Jan 27, 2011 | Office Equipment & Supplies
OCE Plotwave 300. Error Code 22701\printer.
Dec 10, 2009 | Office Equipment & Supplies
689 people viewed this question
k24674
