Question about NorStar M7310 Corded Phone
Remove long distance restriction on nortel phone
Hello, i have a nortel 7316e and trying to reset to factory default. i am entering **7827887 and error message "startup denied" appears. Thanks Nikko
Remember to hit "Feature" first. Dialing **7827887 by itself does nothing.
EG;
1 - Feature **7827887 (STARTUP)
2 - Enter installer password 266344 (CONFIG)
3 - Change to template desired (square, hybrid, or PBX)
4 - Press NEXT to apply the template
Edit: Make sure you have access to the phone pool as admin and that there are no restrictions set on the phone itself. The same thing was happening to others and was detailed here
http://www.tek-tips.com/viewthread.cfm?qid=983869
Feb 23, 2017 | Nortel Computers & Internet
How to Change COS (Class of Service) Password
If you set the all line and set restrictions to no restrictions, you are not restricted from making any calls. I don't think it's the phone system requiring this 4 digit code. Are you sure all your lines are set with the same long distance provider. Did the lines in the dial 8 group require a code. (ie some users had the long distance provider set up their lines to need a code entered to charge calls off to different job codes, so they can distribute the charges correctly).
You should now be able to call 9+1+area code+number, with no restrictions.
Mar 25, 2014 | Nortel Norstar M7310 Display Phone
I have Nortel Networks T7316 and cannot dial out.
Check your cables and make sure everything is plugged in! Also make sure your company doesn't have any restrictions for the number you're trying to call - it can happen sometimes. If everything fails try to consult the user manual.Nortel t7316 pdf manual
Nov 13, 2013 | Nortel Computers & Internet
Restrict calls
Is this on NOrtel or IP Office? Which NOrtel system?
Apr 26, 2013 | NorStar T7316E Corded Phone
How do I remove Denied in Admin from a Nortel phone handset
You don't. Only the administrator who set that restriction can undo it.
Mar 11, 2011 | Nortel T7316E 2-Line Corded Phone
Can you change the password on NORSTAR M7310? I have the restricted line (long distance phone call) and I would like to remove that restriction. Can you help me? thanks Brandon
Yes u can change the password.
Go to system programming by Fetature **266344 password will be 266344.
Keep pressing next until display shows restrictions.
press show there it will ask for COS password press show there u press 00
u will get a pasword press change as per ur requirement.
Jun 26, 2009 | NorStar M7310 Corded Phone
Can't dial long distance from one phone
Sounds like that station is programmed to restrict certain digits (like 1 in the prefix) -- this is usually done by the tech because the owner doesn't want unauthorized calls to take place from a publicly accessible phone. To confirm this, swap the phone with another identical working phone and see if it's still restricted. Good luck!
Jan 29, 2009 | Samsung Phone PDCSLCD12B
How can i remove the "do not disturb' features in my phone Nortel T7208
hey i have the solution. push the function button, then pound, then 85. hopes this helps. i had the same problem and i worked for me
Apr 17, 2008 | Nortel Business Series Terminal T7208 -...
Restricting long distance
in system programming you will need to restrict phones to localcalls only
Feb 01, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
NorStar M7310 Corded Phone Logo
115 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
