Ihave tried to operate advd+r disc on my pc but my pc didn`t recognize it..idon`t know what to do
  • Dick
    Dick May 11, 2010
    You can do the following:
    Use dvd-r discs instead of +r
    Provide the model number and brand of your PC, and service tag or other manufacturer's identification so we can look it up at their support site and tell you what formats your PC will recognize.
  • 26 Answers
A lot of times you can be having a upper and lower filter problem, this is a easy step by step fix for it...........
You can no longer access the CD drive or the DVD drive
Posted on Jan 25, 2009
I needed to know how to play aDVD in bauhn tv
The Braun TV I had some years ago had the DVD slot on the LH side of the screen. With the TV turned on, as soon as a disc was inserted it would start reading the disc and play.
Feb 14, 2015 | Televison & Video
Seagate's DiscWizard, Extended Capacity Manager didn't recognize a hard disc with MBR partition style larger than 2TB when trying to maximize the capacity of the 3TB Seagate ST32000641AS drive...
Seagate Extended Capacity Manager
Seagate Extended Capacity Manager lets your operating system support large size discs with MBR partition style, so then you are able to use the space beyond 2 TB: this free space will be recognized as a separate disc, and will be accessible by your operating systems and applications as if it was a regular physical hard disc.
Seagate Extended Capacity Manager wizard will display all hard discs larger than 2 TB (unallocated or with MBR partition style). You can see, which disc space is recognized and allocated by Windows - this space is called Native Capacity in the wizard.
The space beyond 2 TB is displayed as Extended Capacity Zone. You can enable Extended Capacity Discs, and once it is done, this space will be visible by the operating system and ready for disc management operations.
Click Allocate space to see the possible disc space allocation in the next step.
After clicking Apply changes now button, the Extended Capacity Discs will be emulated on your physical disc. In case your physical disc is larger than 4 TB and the host operating system does not support a GPT partition layout, there will be several Extended Capacity Discs.
Note these Extended Capacity Discs are not bootable, and most properties will be the same as a physical disc's.
After allocating the space, you may temporary switch off Extended Capacity Discs by clicking the corresponding option. This will make Extended Capacity Discs invisible for Windows Disc Management tools, though the disc space will remain allocated.
To disable Extended Capacity Discs, click Remove partitions from Extended Capacity Zone and then click Apply changes now button in the next step: these discs will be removed from your system, and as a result - the disc space beyond 2 TB will become inaccessible
Sep 15, 2011 | Seagate Technology Barracuda Xt...
My dvd drive disappeared from computer/device manager. Drive opens, and spins disc, but isn't recognized by Windows 7.
Does BIOS still recognize the drive? Also, check to make sure the IDE / SATA cord is fully connected, the dirve will operate with power, but wont be recognized without the other cord. If the cords are connected and BIOS reads it then win7 should autodetect it. If its not, it may be the disc itself, try putting something you know for a fact works. If the problem persists, try adding the hardware through the device manager, or deleting all mention of it, then re-adding it through the device manager. This tricked worked for Xp machines, although Ive never had to try it on a Win7 machine, it should still work.
Jul 28, 2011 | Compaq Presario F767NR Notebook
Everytime I put a disc in I get an error saying no disc
Does the disc you insert are original..If not is isn't posibbles for your dvd player to not recognize yor disc cause most of the branded dvd players like you have didn't read pirated disc..but if the disc you insert is original. Try to clean your dvd player using a dvd disc cleaner.
Jul 17, 2011 | Philips DVP5982
HI i want to format my laptop ASUS Model K52JC but idon't have a disc
Normally U can create recovery disk from a menu in the asus itself, if no installation disks were provided.
otherwise U have to buy a oem version of windows, or try installing ubuntu 11 ( free)
Jun 16, 2011 | ASUS Computers & Internet
Itune restore
The iTunes backup / restore instructions are here:
http://support.apple.com/kb/HT1382
Open iTunes.
Insert your backup disc.
iTunes will ask whether you want to restore from this disc. Click Restore.
I don't believe it has to be the same computer. I would suggest trying it to see what happens.
Let me know if that helps!
Apr 18, 2009 | Denon AVR-587
Sansa clip 2gb lockec
First of all, may I ask if you have a mini disc player or a Sansa Clip? Because the Sansa Clip does not play discs of any kind.
If you do indeed have a Sansa Clip you will find the FAQ rather helpful here - http://www.sansa.com/support/sansa_clip/faqs
Question 9 there is regarding devices not recognized by the PC and the solutions are as follows:
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
Clip: Go to Settings > USB mode & choose MSC
If none of the solutions work for you, please post the results of your attempts and we can go from there.
Dec 27, 2008 | Audio Players & Recorders
My printer don't wok
Hi. Im trying to print but I can¨t I don¨t know why, Cause I used to do it but Idon¨t any more.
The printer appiers to be good
Apr 30, 2008 | HP DeskJet F380 All-In-One Printer
I think my burner died
Is the device new? Updated recently? Any changes at all? If there were any changes lately or the device is new there might be compatibility problem, try installing new driver http://sony.storagesupport.com/cdrw/crx1... If the device just stopped working and its not new enough for warranty Take it to fix or try (if you know how) cleaning the laser eye . The easiest way to see if the burner is the problem is to hook it up to another computer and see if it still wont work. Good luck
Feb 23, 2006 | Sony (ODSO52XCDRW89) Burner
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
