Question about Kenmore Oasis HE 27082 Top Load Washer
F-51 error code. washer will not run. - Kenmore Oasis HE 27082 Top Load Washer
    Novelist:
  • 126 Answers
F-51 points to a "motor rotor position sensor (RPS) failure or lower harness problem.
if you are handy with troubleshooting using a multimeter, there are steps here (www.servicematters.com) under technical reference to help you. just enter 27082 as the model number.
Posted on Jan 28, 2009
I am getting an F 51 error code
http://www.fixya.com/support/t3240355-f_51_code_kenmore_elite_oasis_washer
man try a good search
like
https://www.google.co.uk/search?q=Kenmore+Oasis+HE+27082&ie=utf-8&oe=utf-8&gws_rd=cr&ei=M8f4VKCbL8z1Uv2fhKgI#q=Oasis+HE+27082+error+code+51
Mar 05, 2015 | Kenmore Oasis HE 27082 Top Load Washer
Washer does not work it goes into error code f51
F 51 error code means the computer cannot detect that the motor is turning properly. The most common cause of this problem is an article of clothing has gotten between the basket and tub and is stopping the basket from turning freely. There are several other possibilities but I have seen this cause an F 51 error code many times. Hope that helps.
Aug 29, 2011 | Maytag Washing Machines
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
Ddo
Hi
This ddo error code means Dispenser Drawer Open.Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=117979
reference
http://www.fixya.com/support/t2180388-code_ddo
Mar 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Error code 51
there is a rotor position sensor failure.look under the top hood of washer on the inside of the front of washer and you will find a tech sheet that will help with this problem use a flat blade to push two clips in to get hood up.
Jan 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I keep getting an F 51 error code on my washer?
if not under warr. You must replace sensor on bottom of tub along with the wiring harness. This is a common problem with these.
Oct 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio HE washing machine displays error code F51. What is it and hw to I fix it?
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Jul 27, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Oasis HE 27082 Top Load Washer Logo
174 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
