Question about Whirlpool Washing Machines
Whirpooll adg 9040 F2 error
Hi I gwt a F2 error in the display What s I do ?
  • 32 Answers
SOURCE: whirpool microwave
check the operation of the micro switches on the lock motor. that they are open when they should be and closed when they should be. often they need to be cleaned or replaced.
if this doesnt help re post there is some board work to do, i would suggest a tech do this part though. always unplug range when you work on them! If you are good at electronics and stuff and would like to do it yourself then contact me for further support!
Regards,
Vij
Posted on Nov 21, 2007
melnavz
  • 1226 Answers
hello!
Yes, its a shorted keypad, you will need a new electronic control board,
You need to order and replace that., melnavz
Posted on Mar 07, 2008
SOURCE: adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
Posted on May 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirpool model# RF385PXGN (electric) error code F2 E0
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Oct 01, 2010
sodeep
  • 3267 Answers
SOURCE: hi , i have a problem with dcp 9040 printer, it
your yellow toner cartridge is not properly installed.Pull out the drum unit, take out the toner cartridge and put it back into the drum unit again
Posted on Dec 15, 2010
Whirlpool matermind window AC shows error code F2 when power on and won't cool. Sometimes it starts up perfectly fine.
F2 ---for me its a sensor problem had it done thanks katsaras
Unit -- Whirpool AC Model no. Wasr18k20 1.5 ton split AC
Jul 25, 2012 | Heating & Cooling
Whirlpool ADG 4956 - problem F2
Hi, here is the answer for f2 "F2 - error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
Apr 24, 2011 | Whirlpool Microwave Ovens
Whirpool adg 937 integrated dishwasher. the door has started popping open during a cycle. we don't have a manual for it so don't know if its a simple problem, or really needs an engineer?
This should not happen.
There is normally a rocker striker plate and a hook catch that locates into it.
You may need to get a new interlock, these can be quite tricky to replace.
Feb 07, 2011 | Dishwashers
Some time showing on display pannel 51.10 error
51.1 is a beam detect error.
You are probably going to have to have a tech replace the laser/scanner assembly.
Sorry for the bad news.
Jan 25, 2011 | HP 9040 Laser Printer
Hi , i have a problem with dcp 9040 printer, it keeps on displaying " error 3a please check manual for troubleshooting." any assistance can do
Dec 15, 2010 | Brother DCP-9040CN Laser Printer
Adg 3962 IX showing fault code f2 with flashing
May 24, 2010 | Dishwashers
Hi, I am getting an error reading on my whirpool gold stove it reads EO -F2- do you have any clues to what my be my problem. Thank you in advance for your suggestion
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 20, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Whirpool model# RF385PXGN (electric) error code F2 E0 The failure/error display codes says replace control. What is control ?
Jul 28, 2009 | Amana ARGS7650SS Gas Kitchen Range
Whirpool GBD307 - Display not working
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Mar 28, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirpool microwave
take its back to show room give its back its was is in warrenty
do noting if its was in wattrety compny is replaced its free of cost
Mar 07, 2008 | Whirlpool MH3184XP Microwave Oven
Washing Machines Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
