Question about SuperMicro X7DAL-E Motherboard
I can't my bios update.
Dssn't work dos disk.
  • SuperMicro Master
  • 3,606 Answers
Hello visit the homepage here:
http://www.supermicro.com/products/motherboard/xeon1333/5000x/x7dal-e.cfm
For downloading the manual.
You will probably need adobe reader, to read the content.
Here is how you upgrade the bios:
http://www.supermicro.com/support/resources/results.aspx
Remember flashing the bios with a wrong one, WILL destroy the mainboard !!!!!!
Good luck
Posted on Jan 18, 2013
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
I want upgrade bios ga 8simlh rev 1.0,but can not
Jul 16, 2012 | Gigabyte GA-8SIMLH Motherboard
Start-up
you may try to bring up your bios screen to see the boot order and then change it if you can....that would be while booting to tap the f2 or f1 key to get that screen ... then check the boot order, if it says position one is diskette, then try to change it...if you can't change it, get the bios updated then flash the bios....that should do it for you. post back your results
Apr 22, 2012 | Dell Computers & Internet
How can i update the bios on my Hp g60t-200 laptop?
http://www.userdrivers.com/BIOS/HP-G60T-200-Notebook-System-BIOS-WinFlash-Utility-F-3D-A/
May 28, 2011 | Computers & Internet
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
Bios update. I have .bin file, but flash is not working.Chaintek MPM800-3.
Bios is best flashed from a dos (or similar) floppy disk. If you have a floppy then you need to download a boot floppy (I prefer win 98 ones)
and then copy the bin file and the flash utility to that disk.
Bootdisck.com has a selection
Boot from the floppy (you may have to set your bios to do this)
If you don't have a floppy try borrow a usb floppy drive (you may have to tell your bios about it)
If you have windows working there are flash programs that will work from windows.
As with all bios procedures make sure that you have the CORRECT bios for your board. Other bios's will not work and may end up harming your board
Also ALWAYS make a backup of your original bios (best to copy to a flash drive as soon as you can)
Aug 24, 2009 | Chaintech Computers & Internet
Bios verify error
Flashing BIOS from Windows can be problematic. It's usually best to boot from a removable disk and flash from DOS. You can make a bootable floppy using Windows XP if you have a floppy disk drive.
Also, your problem may not be a BIOS limitation, it may be a configuration setting in BIOS such as Clock Speed or a Multiplier. Double check those before trying to flash.
Jun 10, 2009 | Computers & Internet
Bios update using batch
you need the bios update file from your manufacturer and the flashing program that is either included in the package or also avaialbe on the same website, then you basicly need a bootdisk to start up dos and perform the upgrade.
http://www.bootdisk.com/
see the driver free disks for bios flashing.
Jun 16, 2008 | Computers & Internet
UPDATING BIOS FOR ASROCK M266 A MAINBOARD
In order to update your Bios, you need to have a bootable diskette.
First make sure your 1st boot sequence is Floppy Disc. Place a bootable floppy, if you don't have one just do it by using unused floppy. Right click on 31/2 Floppy (A:), choose Format, then tick the box "Create an MS-DOS Startup Disk". Once finished use this disk to boot your system. After the system completed the boot process, replace your boot disk with your upgrade disk. Type the require command to update your bios.
Good Luck
Feb 09, 2008 | Asrock M266A Motherboard
How do I flash my bios when Ican't get into windows.
If you are totally determined that BIOS is the issue, You can use other computer to make a BIOS update disk which can be a floppy disk or CD-ROM. You need to download related BIOS update and write on the media(CD or Floppy) as bootable, here is the link that you can download latest version of BIOS update
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=1362775&moid=513329&rpn=PSP10U&BV_SessionID=@@@@1226560289.1199954361@@@@&BV_EngineID=ccccaddmmkkhhdecgfkceghdgngdgmm.0&ct=DL&all_docs=false
you will see step by step instruction once you download and open the BIOS updater. I hope it will resolve your issue. Please post for further assistance.
Good Luck
Jan 10, 2008 | Toshiba Satellite P15-S479 Notebook
SuperMicro X7DAL-E Motherboard Logo
93 people viewed this question
Top SuperMicro Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Tony
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
