Question about Sony Handycam DCR-TRV350 Digital Camcorder
I have a problem, i have a sony handy cam digi 8(i think it came out in 2000) and i want to usb stream it on to my windows xp computer. But i lost the disk with the software what do i do
Usb handy cam is invalid when i connect my camcorder to my pc
Option 1:
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.(An i.LINK is a black D shaped connector with 4 or 6 pins. The type ofcable to be used will depend on the i.LINK port of your Computer. TheSony Camcorder will have the 4 pin i.LINK cable and if the computer hasthe 6 pin i.LINK port, then you may have to use the 4 pin to 6 pini.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE:As the Camcorder does not support USB streaming with Vista, it is notrequired to use any Sony Device Driver to transfer the video to theComputer. You do not require any Drivers or Software from Sony totransfer the video from the Camcorder to the Computer using thei.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
Ifyou are using a Windows XP Operating System then you have to installthe USB Streaming Driver in the Computer from the supplied Softwaredisk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
NOTE: If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!
Oct 01, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
SONY HANDY CAM DCR-HC18E PAL Need download for usb driver windows vista
http://support.sony-europe.com/dime/tutorials/videotransfer/vtransfer.aspx?site=odw_en_GB&m=DCR-HC18E&sec=DV
Only load the driver and install in XP compatability mode then use another video capture programme Sony does not support Vista for you cam.
FX vid capture will work
http://www.jhepple.com/video_capture_software.htm
If you get stuck you can reach me on marshall.c@sky.com
May 27, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
USB Device Not Recognized
try downloading the drivers from sony first http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C116935&fes=true&mdl=DSCW5 that is if you have already downloaded the proper usb drivers for your system in which case other usb device are still working also it is possible that the usb port itself has gone bad or is in conflict with another driver assuming your using windows to check this you can start by telling me which version of windows you are using but more than likely the proper camera drivers will solve the issue
Apr 26, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Connect sony handycam video hi 8 to a computer
There are lots of devices on ebay for doing this. I have one for just about £15 so pretty cheap. You then play the video through the "red yellow an white plugs" an its converted into USB. Easy to use software too. You can record from a video player or any digital camera or camcorder or ineed anything which has an output of the yellow red an white connectors.
I tried searching for your camera on the internet for a run down on how it connects to a pc but with the model number you gave I got no results?
There might be a small connector somewhere which is infact USB but looks nothing like it! You will find a similar connector on some mobile phones, or an ipod, digi camera etc etc One model I did find says it does streaming straight to USB.
Jan 25, 2009 | Sony Handycam CCD-TRV68 Camcorder
Hi, Pl tell me procedure to load vid data from sony make handy cam to my computer Regards Asit
First you have to install the software.The software is supplied with the handicam in a cd form.You can connect handicam with pc using usb or dv(i link)port.Go to menu in handicam and select usb streaming on.Connect handicam with pc through usb and switch on to vtr mode.In drive C go to programe,sony corpn,DI,capture.Click capure and get capturing window to download your video.
Dec 02, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Usb driver for sony dcr pc55
Compatible Operating Systems
  • Windows® 98 Second Edition
  • Windows® Millennium Edition
  • Windows® 2000 Professional
  • Windows® XP Home Edition
  • Windows® XP Professional
Important:
  1. DVD Handycam and Hard Disk Drive Handycam are NOT supported by this driver.
  2. DV streaming function in DCR-PC1000/E is NOT supported by this driver.
  3. This driver does not support USB Streaming under the Windows 98 operating system.
  4. To ensure that no other program interferes with the installation, save all work and close all other programs. The Taskbar should be clear of applications before proceeding.
Handycam® Standard Definition Camcorder - DCR-TRV285E
or in HERE
Nov 20, 2008 | Sony DCR-PC55 Mini DV Digital Camcorder
How can i get back drives in my sony handy cam?
My computer windows version is Windows vista please send me the USB driver for this camera.
Abebe
Sep 21, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
Sony dcr-trv140 video download
You have to plug your camera into the computer, put it on VCR mode, go to the menu on the camcorder, select setup menu (4th down), usb stream, turn it on. I cannot believe it was that easy.
Jan 29, 2008 | Sony Handycam DCR-TRV140 Digital Camcorder
Sony Handycam DCR-TRV350 Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
