Question about Dell 2155cn AllInOne Laser Printer
Thick black lines across paper when printing or copying
3 Suggested Answers
SOURCE: My DELL 3010CN is printing a thick black line on
Often Toner sticks to fuser. When the fuser heats the toner comes off onto the paper. Should reduce over time unless toner is spilling onto the fuser in the same place.
Change fuser and toner
thanks
Posted on Apr 29, 2009
  • 7 Answers
SOURCE: have black lines on left side of paper after printing
Usually this is occurs when the drum needs to be changed.
Posted on Jun 05, 2012
Thick lines
Check the fusing unit and or transfer belt. Does it print OK not copy! Print Ok means internal OK then check the scanner section
Nov 11, 2013 | Minolta MF1600E Plain Paper Laser Fax
1 black line at the end of paper
if u take copy from adf scanner then clean the scanner glass. if the line is coming on print & copy both then check drum is there any line
Dec 19, 2012 | Sharp AR-5316 Advanced Digital Imager...
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
I have changed the printer cartridge three times. The first two cartridges produces totally black copies; the third one has black horizontal thick lines across the page??? H E L P !
It is may be Problem with printer Fuser.
1.Confirm there is no paper pieces in backside fuser unit.if yes remove the printer cover take out the fuser unit and remove the paper pieces.
2.if there is no paper pieces you must replace
fuser unit Teflon or entire fuser unit. ordinary teflon costs about Rs300.(6 dollars)
Jun 30, 2009 | HP LaserJet 1150 Printer
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Colour lines across the page
Hey Paul, Can you post a scan of the printed paper? It may help diagnose your problem. The most common cause of lines accross the page is either the PhotoConductor Unit or the 2ND BTR Assy.
Nov 30, 2006 | Epson Aculaser C1100 Printer
Dell 2155cn AllInOne Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
