Question about Hitachi Air Tools & Compressors
How do you oil hitachi nr 90ad strip nailer - Hitachi Air Tools & Compressors
5 Suggested Answers
  • 1388 Answers
SOURCE: i own a hitachi nr90ac3 framing nailer and i
Oil leaking out of the nailer anywhere is just an indication that too much oil is being introduced. A good solution would be to reduce the amount of drops until no more leaks out or use an in line oiler at the gun. An oiler costs under ten dollars and feeds in oil vapor as you use air. Store / hang your nailer with the air inlet down at night to drain out access oil. Do not worry too much about the leaking though, I think that a bit too much oil is better than a lack of oil. Good luck.
Posted on Apr 10, 2009
  • 1388 Answers
SOURCE: Reassembling the Hitachi NR 83A2 (S) magazine
The reason that you are having trouble re-assembling the ribbon spring is that you need three hands to complete the job. As you recall the nail pusher just slips into the front of the rails. The pusher has the spring and a pin to retain the spool in place. Install the spring with the bolt hole towards leaver and slip into the front of rails. Take a small paper clip and bend a small hook to catch the ribbon spring. Hook the springs bolt hole with the paper clip and hold the spring in the approximate position for bolt as you push the assembly into rails and use latch to hold. While holding spring with paperclip, insert bolt thru rails and spring into nosepiece. Just break off the paperclip at this point and you are almost done. Some nailers have a metal support clip that you would need to have in place on bolt before installing bolt thru spring. For a breakdown of the gun go to www.toolpartsdirect.com. The other bolt for rails has a support/guide for the safety foot. Good luck and email if you have questions.
Posted on Apr 12, 2009
  • 232 Answers
SOURCE: It will double fire sinking second nail only half
the pin pushing your nails is loose and the guides are warned .
try to change the guides and you will see that this problem will will be gone .
one last thing , make sure the coils are in good shape as it may create some feeding problems and push 2 nails at once
Posted on Sep 26, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a hitachi NR 83A2 framing nailer with a
by jammed I take it you mean a nail has jammed the driver? If that is the case there is really no easy to unjam it. But unplug the air hose and turn tool upside down and wearing safety glasses and gloves you can try and take a punch smaller than the nose piece and try hitting the driver to unjam nail. If it is another problem please let me know and I will try and help more.. Sometimes we used to have to remove the nose and heat and it goes on but hopefully it is not that bad
Posted on Feb 05, 2011
Hitachi nr 90 gc2 nailer wont fire
Various reasons, secondary switch faulty. gas out of date, gas is colld, iar leak, faulty spark unit.
Suggest you get it checked out at a repair centre.
Jan 04, 2013 | Hitachi NR90GC2 Cordless Gas Clipped Head...
My hitachi nail gun just fire one time and the piston stay out
This is most likely caused by the band (or o-rings) on the outside of the cylinder. It could be a trigger valve problem, but the fact that it doesn't come out until the trigger is pressed points to the cylinder rings.
Apr 22, 2012 | Hitachi 3 - 1/4" Framing Strip Nailer
My hitachi nr 83a leaks air at the trigger
Often a trigger leak in the NR83A is caused by a bad gasket in the head #877-327. If this is improperly installed, cracked, or overcompressed it will cause the trigger to leak.
It is uncommon for the trigger itself to be the problem.
Sep 24, 2010 | Hitachi Nr83a- Strip Nailer-driver Blade...
My Hitachi NR 83aa2 framing nailer randomly misfires. Sometimes several times in a row, or every other nail. What can I do to remedy the problem?
Do you use air tool oil before each use? Does the compressor have a decent air filter? Are you getting water deposits in the nailer? You may need to install a line-filter to trap water/debris in the hose. Hope this helps!
Aug 08, 2010 | Garden
I have a hitachi 2nd fix gas nailer and im not sure were ,and how often to apply the oil as iv managed to lose the instructions . hope you can help
Depending on how much you use the tool. Only apply oil to tool after you have given tool a strip and clean. Or for General maintence just 4 - 6 drops of oil every 3 - 4 week only if you use tool more then 3 times a week( 10,000 nails).Only on the fan assy O-rings.Remember this is only a guide.But if you need more info then try the hitachi web sit or your nearest nail gun repair agent.Good Luck
Nov 01, 2009 | Hitachi Tools & Hardware - Others
I own a hitachi nr90ac3 framing nailer and i
Apr 10, 2009 | Hitachi NR90AE Full Round Head Framing...
Air Tools & Compressors Logo
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
