Question about Samsung E340 Cellular Phone
I can't switch on
I have samsung E340.i drop the phone now it can't switch on.and also i put in charger no displayed no change same problem.i unscrew all the screw and brush it to make clean without any no change .pliz help
4 Suggested Answers
  • 128 Answers
SOURCE: Problems with Samsung cellular phones
100% there is liquid damages inside.Take the phones 2 a technician and he mayde can fix it.
Posted on Jun 29, 2007
  • 137 Answers
SOURCE: samsung d 500 mobile phone
Port at bottem shorted. Cleane it. If it doent helpproblem is deeper, then it is your phones charching ic that is damage.
Posted on Dec 25, 2007
  • 59 Answers
SOURCE: i bought samsung mobile fone without english manual pliz help
Hello daviejonatha,
There is the English Manual of E250 Download it through this LINK
Thank you for using FixYa.
Posted on Apr 22, 2009
phoenix chi
  • 389 Answers
SOURCE: Samsung Blackjack II has a bright white display
Once the phone has been exposed to any form of liquid or moisture it will damage the mother board of the phone, it will cause corriosion and no assurance that the phone can still be repaired.
Posted on Jul 07, 2009
0 characters
1 Points
My cell phone is not switching on,its samsung s5233w
You have many possible reasons:
1. Phone battery is off. Connect the charger and charge the battery
2. Charger does not work: you can check that by connecting a voltometer at the output of the charger and check the voltage. If you see no voltage, most possible reason of failure is the cable coming out of the adapter. Change it and check voltage again.
3. Battery metal probes are not clean: clean them
4. Battery is dead and needs replacement. You can check this is you remove the battery and put the charger on the phone. If the phone boots, it was battery's fault.
5. Phone needs opening and checking of the circuit boards. Possibly a component is broken there. If not, the damage is not visible and need to change the board or the phone.
If this solution helped you, take a minute to rate me.
Aug 04, 2011 | Samsung Star GT-S5233 Cell Phone
My Samsung A707 acts like it's trying to restart continuously. It gets 80% through the start up (based on progress bar on bottom of display) and then restarts again.
This type of thing usually happens when your phone is connected to charger that provides insufficient or far more power that is required to charge your phone.........but if your phone is not connected to charger then first put a piece of paper or any thin material with your battery in order to get it more closer to jumper(the terminals at phone where battery is to be conected) if the problem still exists then try to change your battery.
Oct 01, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Jul 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Got my pin code.i need a sim lock code
Let the mobile be of any model puk code is required to open pin1 and pin2 Personal Identification number. PUK code can be given only by your customer care. You shall call your customer care and ask them for PUK they will ask your personal information which you submitted while purchasing the sim card and the number which is printed on your sim. In turn they will give you your PUK code number which you can insert in ur mobile and open your sim.
Jun 16, 2009 | Samsung E340 Cellular Phone
Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
For more information and links to the parts check the following link below.
Samsung SGH-D900 charging problem repair
May 13, 2009 | Samsung SGH-D900 Cellular Phone
Switching off frequently
you want to put new software to your mobile! then the problem does not come!
Jul 01, 2008 | Nokia 3110 Cellular Phone
Sansung d900 wont work
Take The Battery Out,Give It A Wipe Inside,Take The SIM Out And The Put It All In A Again And See If It Works.
Otherwise See If It Can Be Repaired By Warrenty?
Good Luck :)
Mar 02, 2008 | Samsung SGH-D900 Cellular Phone
Samsung T809, screen display is dull(week)
unfortunately, the board of your mobile phone has corroded. When the water dried up rust was developed. try cleaning the board of your phone...
Jan 02, 2008 | Samsung SGH-D820 Cellular Phone
Jun 29, 2007 | Samsung SGH-E370 Cellular Phone
Open Questions:
e340 supposed problem Good day. My daughter has had a Samsung E-340 for 13 months (as luck would have it, one month outside of warranty). The phone developed a slight problem, it froze occasionally while my daughter was creating a text message. We took it into the agent who immediately sent it away for "repair". We received the phone back with a R340.00 bill and we were informed that it was a software problem and the software needed to be reloaded - rubbish. They cleared out the phone of all text messages as well as phone numbers - I thought it was good practice to inform the customer before this was done. We switched on the phone, it froze immediately, and continued to do so on a more regular basis. We returned the phone for a second time, this time we were informed that it was not the phone but the network - rubbish. If it was indeed the network, all the phones in Pretoria would have been sitting in the agents office. The phone was in an even worse condition, the screen flashed at will and just switched off on it own accord, we returned it again to the agent and he himself acknowledged that is was in a much worse state that the previous visit(s). The phone was returned once again, this time the phone didn't even switch on, the agent tried a new battery and still no joy. The excuse this time was that this particular phone does deteriorate gradually and then die completely. I find this hard to believe, especially after only 13 months. This is not a good advert or indeed support for what I think is a good product, until of course our recent experience. Is there anyone out there who can help us with this rather painful problem. I repeat, not only is the publicity bad but the actual support does not exist. Kind regard
Sep 04, 2007 | Samsung E340 Cellular Phone
See all Samsung E340 Cellular Phone Questions
Samsung E340 Cellular Phone Logo
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
