Question about Stanley Black & Decker Garage Door Clicker Stanley 1082
Stanley 1050 garage remote wont open the door
Motor working but door won't open- tries but wont open
My stanley garage door opener's chain snaps everytime i open with remote
have you checked the chain tension adjustment for proper amount of deflection? This is listed in the manual that comes with your garage door opener. Usually, the chain is too loose from the problem that you are describing. I would check online for the manual if you don't have access to yours. Also, the travel adjustments for stop (up and down resting positions) would be explained as well.
Oct 06, 2012 | Home Security
Garage door opener won't work
Motor has overheated; the motor unit does not operate or trolleyis stuck on stop bolt = Motor unit hums briefly; RPM Sensor =Short travel 6-8" (15-20 cm).• Unplug unit to reset. Try to operate motor unit, check diagnostic code.• If it is still flashing 5 times and motor unit moves 6-8" (15-20 cm), replace RPMsensor.• If motor unit doesn't operate, motor unit is overheated. Wait 30 minutes andretry. If motor unit still will not operate replace logic board.
Aug 30, 2012 | Craftsman 3/4 Hp Garage Door Opener System...
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
Apr 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
My nephew kept opening and closing my garage door, now the door won't open with the opener and I can lift it by hand. I tried pulling the cord to move it back to electric but it won't work... any...
The motor has a thermal protector that will cause the motor to quit when it gets hot. If you let it cool off it will automatically reset and should work again.
Jun 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
I bought a house with an old (1980's) Sears garage door opener. I have two Stanley remotes that were in the house at the time of purchase. The opener works fine at the hardwired button in the garage but I...
On the remotes put switch #1 in either position and match up switches 2 through 10 to the dipswitches on the motor unit. There is a good possibility your receiver has quit working.
Mar 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Stanley Black & Decker Garage Door Clicker Stanley 1082 Logo
Top Stanley Black & Decker Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Stanley Black & Decker Building Material Expert? Answer questions, earn points and help others
