Question about Bosch WTE86300 Electric Dryer
How to access fan wheel on bosch WTE86300US dryer for cleaning
I have a Bosch Axxis non-vented dryer and clean the filter and lint trap regularly. I think that lint has accumulated on the fan wheel and would like to clean it. I suspect there is a way to pop off the cover (the vented panel just to the right of the filter door), but I'm not sure how to do it and don't want to break any of the plastic parts. I have found that there are several parts that should be regularly cleaned that are not mentioned in the maintenance section of the owner's manual.
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
SOURCE: bosch axxis WTL lint indicator problem.
I have been struggling with this lint filter problem big-time. After reading the previous user's comment that his mesh holes had become clogged, I took a closer look at my filter and noticed that the tiny holes in the mesh were, indeed, clogged up. In fact, when I initially ran water on the filter it pooled up on the mesh like a solid plate...pretty good sign that air wasn't able to pass through the filter properly.
I used a soft toothbrush and soap to clean the filter, and when I ran water to rinse it off it the water passed right through the mesh. I popped it back in and, voila...That fixed it!!
Posted on Apr 20, 2008
  • 864 Answers
SOURCE: Bosch Axxis dryer - lint filter indicator lights up
Make sure the exhaust vent duct is clean all the way to the outlet.
Posted on Nov 11, 2009
  • 51 Answers
SOURCE: WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Posted on Feb 02, 2010
ftw1952
  • 10319 Answers
SOURCE: We have a Bosch Axxis WTA 3510 electric dryer.
Remove the exhaust venting tubes and clean thoroughly. When lint builds up the moister sensor prevents the burner to 100 % hot causing thsi
Posted on Jul 08, 2010
FILTER/VENTING HOSE LIGHT IS ON
Clean lint filter screen and area were it slides in
Axxis lint screens are very fine fabric softener will clog it up may need new one hot water for about 40 min unit may need complete clean out
Jul 02, 2015 | Bosch WTV76100US White Axxis Series Vented...
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
How to fix recurring F09 error in Bosch condensing dryer WTE86300US
How long is the connection including the duct work in the house?
Jul 31, 2014 | Bosch WTE86300US Axxis Electric Dryer
Hi! We have a Bosch Axxis gas dryer that runs for aprox 40 seconds than stops and "Beeps" and the "Drying" & Wrinkle Block/End" lights flash. I have tried running it empty...
your sensor is either dirty, most likely or bad. it is located under the lint trap. if you look down you will see it it has tow screws, be careful when cleaning it as it may break.
Feb 18, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Feb 02, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Nov 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Lint Error and shut down on Bosch WTA 3500
Hold the filter up to the light ,can you see thru it? wash with soft brush.filter sensor located inside duct right inside door ,clean off.look 1 inch silver probe.Hope this helps ,please rate my response :)
Jun 15, 2009 | Bosch Axxis WTA 3500 Dryer
Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Bosch WTE86300 Electric Dryer Logo
47 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
