Question about Ruud Central System Air Conditioner
Ruud furnace won't stay lit.
Our Ruud furnace has an electric ignition. When it get so hot the flames come on. But the flames only burn for about a minute then it cuts off. It is not reaching the temperature we have set on our thermostat. Do these kind of furnaces with this tye of starter have thermocouple. It reminds me of a furnace with a pilot lite. The fan goes ahead and blows for a while.
  • 2 more comments
  • kenneth889 Jan 29, 2009
    I have a Ruud Mod.#UGRA-07EMAES with same problem. Burners ignite for a few seconds and then go's out. The circuit board has a flashing yellow light. The troubleshooting chart on the furnace says to clean the flame sensor and if this does't work to replace the circuit board. Is there something else I should check before I buy and espensive board?
  • kburns1016 Apr 02, 2009
    I have a Rudd Model #UGRA-07EMAES 90 Plus Gas Furnace with a similar problem. Once it is turned on the inducer fan comes on, the igniter glows, the flame appears, the fire roars for a few seconds then the far left burner goes out causing the unit to shut down. We just purchased the house and prior to closing, all the utilites had been turned off for about a month. Prior to the utilites being turned off the furnace did work.
    We had the gas company come out and make sure we were getting the proper pressue into the house, and we cleaned the unit thoroughly.
  • Ken Bledsoe May 11, 2010
    When you say flame comes on for one minute is it that long or maybe just 20 to 30 seconds?
    Also is the air filter clean?
  • Howard Sexton Oct 06, 2012
    We have a new Ruud and it was doing the same thing. Found a spider nest in the fan vacuum line.
    Scholar:
  • 144 Answers
Hi, welcome to Fixya. If you have spark ignition turn off the power and using sand cloth clean the rod(s) and hood of the spark ignition. If it is a Hot Surface Igniter (glow coil) look on the opposite end of the burners and you will see a rod protruding in to the flame. It's called a flame sensor. Clean it with the sanding cloth. If either of these works then you bought some time but should consider replacing the part fairly soon. Please report back to let us know your progress. Good luck.
Posted on Jan 25, 2009
    New Friend:
I had the displeasure of working on a Rudd GRA-70MAES spark ignition furnace and I never want to see one again! The circuit board would intermittently shut down the ignition after about four seconds and it takes six to seven seconds to open the gas valve (this problem has existed for years and no one has been able to fix it). I replaced the gas valve and the circuit board and things just got worse. I noticed the schematic diagram showed the "C or Common" terminal of the circuit board terminal strip as being grounded so I checked and there was no ground. The "C" terminal is also connected to a nine pin socket on the circuit board that has a nine pin plug with pin #9 of the plug connected to a ground wire. I removed the plug and pin #9 is grounded as it should be but there is no ground on pin #9 of the socket. The answer is there is a green (ground) wire connected to the nine pin plug but it is on pin #1 which connects to nothing on the circuit board socket. By the way, pin #9 is in the lower left hand corner of the plug and pin #1 is in the upper right hand corner. If you have a green wire in the upper right corner of the nine pin plug, you have one of Rudds mistakes. Rather than trying to get Rudd to admit to stupidity, try connecting a wire from the "C" terminal strip on the circuit board to a screw on the blower or any other ground and see if it does not cure your problem. Why this furnace ever worked in the first place is beyond me and why no one ever could fix it is obvious. Do yourself a favor and buy another brand furnace next time.
Posted on Feb 16, 2013
I had the same problem with a new Ruud furnace. Found a spider nest in the fan vacuum line. Works great now.
Posted on Oct 06, 2012
I have the same problem, but already replaced the fllame sensor with a brand new one. Still having the same problem. Any other ideas?
Posted on Mar 01, 2010
  • magnaduke Nov 06, 2010
    My unit had an error code for flame over switch open. Found it was my number 1 burner not shooting through the heat exchanger tube as the other 5. Orfice was fine. Talked to a local dealer and he said the echanger tube was split or messed up and I could just block off that burner and it would fine. Replaced orfice with plug and so far it is working.
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
Lighting pilot on Ruud 80 plus furnace?
Hi, There is no pilot and the flame is lit by a hot surface ignitor... The hot surface ignitors go bad frequently...you probably need to replace that...
Here is a tip that will help you try to figure out why your furnace is notworking.
BasicFurnace or Heating System Troubleshooting
heatman101
May 14, 2011 | Ruud Heating & Cooling
Thermostat calls for heat, purge motor turns on, 15 seconds later hot igniter turns on, then gas turns on and burners are lit. Problem is, they only stay lit for 5 seconds then shut off and cycle repeats...
,Hello, Make sure the flame sensor is clean near the burners, The flame sensor is a metal rod that is on the opposite side of the ignitor. To clean the flame sensor you will need some steel wool, turn off power to the furnace and remove the flame sensor and clean it with the steel wool. After cleaning reinstall it and turn power back on to furnace.
Mar 02, 2011 | Goodman Heating & Cooling
I have the same Ruud Achiever unit & it's not working.
It sounds like it will need a hot surface igniter. This is the part that glows when furnace is turned on, and tells gas valve to release gas for it to ignite. At that point funace is lit, it heats up flame sensor witch inturn tells fan to start.
Sep 30, 2009 | Ruud UBHC Air Conditioner
Ruud Silhouette II Fails to Ignite
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
Jan 13, 2009 | Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Ruud Achiver series Furnace issue
Sounds like it may be a bad flame sensor. After the ignition, the flame sensor needs to send 24v back to the gas valve to indicate the the ignition took place. If it does not do this, the gas will shut of as a safety precaution. The flame sensor can often be cleaned up with a piece of sandcloth to fix this problem, or it may be replaced.
Dec 14, 2008 | Ruud Heating & Cooling
My Ruud Furnace wont stay lit
Hi Bmreid
The problem you describe sounds pretty much like your gas valve is going bad. There is a brand by Honeywell called a Smart Valve which is anything but smart, when the electronics in the valve start going bad the furnace will run great for a day or two and then the next day may not run at all and then an hour later my run and then an hour later may not run again. Very sporadic operating furnace is usually the Honeywell Smart gas valve going bad.
Nov 15, 2008 | Kitchen Appliances - Others
Heater lights for about 5 sec and then goes out
One flash on a Ruud furnace indicates failure to ignite. There is a viewing port on the furnace where you can watch the flame. If the ignitor is igniting the burner and then 2 or 3 seconds later, the flame goes out; you most likely have a flame sensor that is dirty or not working. Check to make sure you are getting gas. Check the connections of all wires to the control board. If the sensor is not part of the ignitor, see if you can get to it to clean it with a small wire brush. Make sure there is a good ground connection between the board and furnace frame. If the flame is not traveling all the way to the flame sensor, clean your burners. If the flame burns inside the burners, you may have weak gas pressure. Good Luck.
Sep 29, 2007 | Heating & Cooling
Ruud Central System Air Conditioner Logo
2,984 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
