Question about Husqvarna Chain Saw 20" Bar
Husky 359 clutch bearing lube tech
I am not sure as to the maintenance procedure for lubricating the clutch needle bearing on a Husky 359. The owners manual is useless in that regard.
Please advise.
Thanks much.
  • carlc137 Jan 26, 2009
    I assumed as much and did so ( lubed the access hole with a small grease gun in the center of the clutch) But was not sure if that was actually reaching the bearing. I appreciate your prompt and very helpful response. Thank You.
  • 6 Answers
Remove the chain brake cover and check the end of the crankshaft to see if there is a small hole for the roller nose lube gun that should have came with the saw. If so, inject a couple of pumps into this hole which will put grease into the bearing.
If no hole exists then you will have to remove the clutch housing from the saw which can only be done easily with an air or electric impact wrench. The nut comes of in the OPPOSITE direction (counterclockwise) that the nut rotates in when in operation - this should be very easy. Then remove the clutch housing which will expose the needle bearing and using your fingers smear the bearing with a small amount of light high pressure grease. Then replace the clutch housing and turn the nut in the opposite direction you used to take it off with your fingers until it is snug - then use the impact wrench in a very short burst to tighten the nut. Finally replace the clutch housing and/or bar and chain.
For a casual user this should only have to be done once a year as good quality chain oil can get into this area and provide some lubrication.
Posted on Jan 26, 2009
How to adjust a carbureter on a 359 e-tech
That depends on where you bought the saw. if in CA, there will be limiter caps on the adjustment screws that will limit how much you can turn them. The saw will have to be taken to an authorized Husky dealer.
Oct 14, 2014 | Husqvarna Garden
I have a 455 rancher.I take very good care of my equipment but. the manual states to lube the clutch bearing.How can I do this with out tearing the clutch apart.It may also need special tools?Any help...
The passage in the operatore manual is the same in all mauals, it is taken from the pro saw manual, here you can grease the bearing through the end of the crank, you cannot do this on the 455, you do need to remove the clutch and drum, the reality is that the drum bearing is only turning if the saw is idling without the chain rotating, the crank then turns in the drum, unless you leave the saw idling for long periods of time ( this is bad practice ) the bearing is doing very little, there is normally plenty of oil flying around to lubricate it, to remove the cluch there is two cut a ways in the clutch spider, these are designed to take the screw driver from the combi wrench, with a suitable hammer jarr the clutch against the compression of the saw until it un spins from the crank ( left hand thread )
Jul 19, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
How do you remove the clutch from a model 359 chainsaw?
There is a special tool available, or you can insert a flat blade screw driver into one of the slots in the clutch centre ( they are designed for this ) and strike the end of the screw driver with a suitable hammer againt the compression of the saw, the jarring will eventually loosen the clutch, it is a left hand thread.
Jun 16, 2011 | Husqvarna Chain Saw Maintenance Kit 357xp ...
How to lubricate needle bearing
Remove the clutch cover by loosening the 2 bar nuts. Lay the saw on it's side with the clutch drum facing upwards. Drip engine oil into the centre of the clutch drum while rotating it. That's all there's to it.
Nov 17, 2010 | Husqvarna Chain Saw 20" Bar
HOW DO I REMOVE THE CHAINDRIVE CLUCH ON A 359 SAW
My 359 has 3 detents rather than 2 but other than that is like the video.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you need them, part numbers for Husqvarna and Oregon rim sprockets can be found below.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 27, 2010 | Husqvarna Chain Saw 20" Bar
How do I reset the chain brake on my husqvarna chain saw
You can download an Operator's Manual and IPL for your 359 here:
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
On the IPL for the serial number used as an example (my 359), the eared part of 503 89 08-02 must be rotated Clock wise to open the chain brake. In the clutch cover it is the uppermost left component. Some say a crescent wrench works well. It may require some amount of force and a block of wood in the cover and a C-Clamp to a work surface may make it a little easier. Good Luck
Lou
Jan 09, 2010 | Garden
Husky viprating on tick over and now wont start
I think you are saying it sputters but won't run. Once it attempts to fire open the choke or it may flood. My 359 start:
Cold: pull out choke control, pull starter (usually twice) while listening for attempt to start. Once it fires push choke control in and
continue pulling (usually once more).
Warm: pull out choke control (sets fast idle), push choke control in, pull starter.
Page 19 of my manual.
Lou
Once flooded these are a bear to start.
Aug 25, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Needle bearing maintenance
use a plastic piston stop and the proper clutch removal toop. Try Baileys on line or Madsens saw shop for the removal tool. Must order for the specific model, but they are rather cheap.
Oct 24, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
857 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
