Question about Emerson MW8777W Microwave Oven
What size fuse does my 700 watt micro wave use
2 Suggested Answers
  • 1015 Answers
SOURCE: Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Posted on Dec 24, 2009
I have a emmerson 1000 watt microwave its about 3 or so years old. it stays on even when the doors open. so when its done and u take it out, it keeps on going around?
micro-switch if faulty or in stuck position thinking that it is okay to start/run microwave . these machines are mostly made in china and are sensitive of slamming the door too hard the plunger that insets into wave there is a micro-switch, you will have to take apart the wave..sorry ..
Oct 14, 2017 | Microwave Ovens
I have a 2500 watt cobra inverter and I'm trying to get my 700 watt microwave to work but it keeps poping the breaker and shutting off Not sure why
Instantaneous surge current can trip the breaker. You need to look at the data plate on the oven to see what the actual draw off the mains is. 700 watts of microwave power is NOT the amount of power drawn when it starts. You have the fan motor and the tray rotator motor to deal with when calculating the correct size of inverter to use with it.
Sep 21, 2016 | Microwave Ovens
Where are the fuses in my microwave oven,?
Inside behind the display panel on a small circuit board.
Jan 01, 2013 | Magic Chef MCO160UB Microwave Oven
What is the size of Haier 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK?
The of the Haier 700 WATT MICROWAVE TOUCH 0 7 CU FTBLK is 17" W x 10 3/16" H x 12 7/8" D.
Jul 15, 2012 | Haier MICROWAVE TOUCH
My microwave does not heat as hot as it use to. What would cause that.
Here is a simple power test.
Place a measured cup of water into the microwave. Run the micro for 2 minutes. A 1000 watt micro will boil a cup of water in 2 min. Check the power output of your machine. It will be found on the model number tag. A 700 watt micro will take about 3 minutes. If this occurs, the machine is working properly.
Otherwise, check the outlet voltage, should be 110 or higher.
Outside of this, you could need a high voltage capacitor or magnetron.
Dec 30, 2010 | GE Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
I need to know the size of the bolts to hold the micro wave up to
You can download GE owner's manuals and installation instructions here.
The installation parts should be detailed in the installation manual.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 02, 2010 | GE XL1800 1100 Watts Microwave Oven
PAINT IN MICRO WAVE OVEN
It will have to be sanded smooth and clean and dried thoroughly.
Then you can apply high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 21, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Emerson MW8777W Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
