Question about Sharp AL 800 Copier
Sharp AL 800 won't copy. Blinking letter and number H 2
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Jan 28, 2009
Contact number for technical support for AL-800 copier machine
You can find information here: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?model=AL-800
The USA support number is 1-800-237-4277 (1-800-BE-SHARP) Other numbers are at http://www.sharpusa.com/CustomerSupport/ContactUs.aspx
But the model is old enough that there may not be any phone help available.
Sep 25, 2011 | Sharp AL 800 Copier
My sharp al-1530cs keeps flashing a L and will not copy
L what? These Sharp machines will flash a letter followed by a number such as L 1. The L1 is the most common so I will give you my link for that solution. If this is not correct just reply back with the code you have.
Good Luck and Thank You for using Fixya.
WheatlandServices
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
Nov 05, 2010 | Sharp AL-1530CS All-In-One Laser Printer
AL 1631 Grayscale Copier: letter h is blinking in the display unit does not ...
all the codes with(H4,H3,.......)can be removed by simulation 14
May 16, 2010 | Sharp AL 1631 Copier
How can i reset the drum on al 800 sharpgrayscale
You should have on the right side of the display panel a "C" key and on the far left side your "light" exposure key.
Press c-exposure-c-exposure the scree should go blank. using your key pad make the display show 24 then press your copy key. then make it show 7 the press your copy key. Press the C or CA key until the copier resets. The light should have gone off.
Oct 14, 2009 | Sharp AL 800 Copier
Sharp AL-800 light copies
Check the machine for a **** or dust glass above the drum.
Check and clean coronas, the wires and shells may be dirty reducing charge.
Run a few white copies, to check of the toner / carrier ratio is low.
Hope this is of some help.
Ed
May 11, 2009 | Sharp AL 800 Copier
Sharp AL 800 won't copy bottom 2 inches across page. Replaced toner cart and still missing bottom 2 inches across page. What do I try next?
Pretty sure you need to replace the drum cartridge. When the drum blade goes bad or edges of the drum go bad it will cause this issue. You can stop a copy as it is passing thru and compare the edge as it is being transferred to the drum and what is on the paper to see what I am talking about.
I can be more specific if necessary
Thanks
TankMurdock
Apr 24, 2009 | Sharp AL 800 Copier
Blinking letter L
The scanner probably got locked. If you reach up under the scanner in the cavity where the copies come out, there is the locking mechanism. turn it 90 degrees to unlock it. turn the copier off and then back on to clear the code.
Apr 16, 2009 | Sharp AL 800 Copier
Sharp AL 1631 Drum Icon only blinking
Hello sir; After install drum unit you need to reset, the procedure as follow;
1, press "#", "*", "clear", "*",keys.
2, enter 24 press start enter 07 press start.
3, turn power off and back on.
Jan 31, 2009 | Sharp AL 1631 Copier
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
Sharp AL 800 Copier Logo
98 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
