Question about Unknown Compatible Hp Ce255x-micr For Hp P3015 / 3015d / 3015dn / 3015x 12.5k
Load micr toner error - Unknown Compatible Hp Ce255x-micr For Hp P3015 / 3015d / 3015dn / 3015x 12.5k
WHAT IS HE SERVCE CODE PIN #. OR HOW DO I GET INTO THE SERVICE MODE
hp LaserJet P4015: 05 4015 08
hp LaserJet P4515: 05 4515 08
depends on which model you have, choose the correct code above. These are the HP numbers but I do not think that Troy changes them when they install the MICR upgrade.
May 29, 2015 | Troy HP Laserjet 4015 4515 Micr Toner HY...
Tip
Laser printer refills Cause damage over time.
Hello my fellow fixya users.
I got a huge tip for your and the reason why I post this tip is to save you on huge repair cost or ultimately the replacement of you laser printer.
My church recently fell victim of there Dell laser printers giving out. I was asked as a tech why?
I asked them well are you using original toner from the manufacture our are you paying some dude $50 bucks to refill that toner?
Low and behold they where using re manufactured refilled toner cartridge from a company that did not pass inspection.
So I had to replace there DRUM after only 3 months of use of this printer. Dell did not want anything to do with warranty because they decided to save a few extra bucks.
the issue is:
1. Lubercation of the movable parts
2. Corrosive toner (ever heard of that?)
3. The sensor mimics a FULL message to the on-board circuit in the printer thinking its full so it will just print. (This causes paper jams and all other sorts of malfunction.)
Now I respect other reviews on fixya.com and visited the refilled idea myself in the past until i discovered my failures as well.
Do not be fooled by people trying to bait you into ink programs or toner programs your life of your printer depends on it.
I wear badges on fixya for a REASON, It's because our community of aker's feel I have what it takes to support them in those areas. Make no mistake about this folks refilled/remanufactured is for the birds!! Yes you save money and yes it does work fine, but not for long!!!
Do not let me catch you at Best Buy or any store with a brand new printer in your hand just because you wanted cheap printing.
You get what you pay for! Buy cheap ink get cheap results. Buy re manufactured toner and get a re manufactured printer back from your manufacture!!!
Trust me I done plenty of homework on this. My church put me on there technical advisory committee for a reason!!! They feel I know what the heck I am saying and you will too.
Just give it time!!
Do not trust me click this!!
http://www.sourcetech.com/printers/micr-toner/micr-toner.asp
Keywords:
gps, home theater systems, home theater, tv repair, computer repair, laptop, repair, computer, laptops, home, computers, desktop, pc, parts,printers,refills,printhead,plunger,refilled ink.re manufactured,toner,cheap toner,toner refill,hacks,toner,fixya,laser printer,epson,dell,toshiba,okidata,warranty,printer repair,service manual,
on Apr 29, 2010 | Office Equipment & Supplies
Load MICR toner or click OK six times to cancel job
IN THE PRINTER HP 4250 INSTALL CARTRIDGE & SEND THE PRINT & ERROR IS LOAD MICR TONER & SIX TIME CANCLE THE JOBE
Oct 17, 2013 | HP LaserJet P4015N Printer
How do i link my tourer to the computer
Peace on follow Al Hoda either after do open a reproduction of the back of and disassemble the kart and the one after the other clean it very promising and then linking them properly if your printer does not work this means that there is a malfunction in the kart.
Aug 24, 2013 | Lexmark TROY Systems Optra T...
I dont know how to refill the ink of my printer please help me iP1980
How To Refill Ink In Printer Cartridges – Video Instructions
Inkjet toner refill - Beware: Non-original Toners Can Cost 31% More Than Original HP! www.HP.com/IN/Toner Stop Check Fraud Now - Prevent Check Fraud with Source Technologies MICR Printers! www.SourceTech.com This video illustrates the various steps required to refill printer cartridges at home using disposable syringe and a bottle of printer ink.
Jan 29, 2010 | Office Equipment & Supplies
1332 infoprint printer not supporting 1332 toner cartridge
If the toner in the machine is NOT MIRC it will not work in a MIRC printer. Get the correct toner cartridge or get a NON MICR printer to put your toner in. MICR uses a special toner (magnetic) for printing checks and the printer is usually modified at the factory (troy or others) to make it print using MICR toner. No way around it.
Aug 14, 2009 | IBM Infoprint 1332 Laser Printer
Flashing amber warning light
The problem is that the MICR Toner Wire was placed into the wrong jumper position on the TROY Font Card. By moving it to the other jumper, this should clear your 'Invalid Toner Sense State' Error. If you need further assistance, please feel free to contact me at 800-633-2266 x 218 or vial email to bmcmillen@troygroup.com.
Regards,
Brian
Mar 20, 2009 | Troy MICR 2200T Secure Laser Printer
ERROR MESSAGE READS "LOAD FILE AND EXECUTE" HELP?
It is possible that the printer is somehow waiting for a firmware upgrade file. If you power off the printer and remove the TROY Font DIMM, then power on, does the issue message still appear? If it does not then the problem could be the TROY Font DIMM. If it does then I would look at the Formatter. If you need any further assistance, please feel free to contact me by calling 800-633-2266 x 218 or via email to bmcmillen@troygroup.com.
Regards,
Brian
Feb 10, 2009 | Troy MICR 4200 Secure Laser Printer
Brother HL-5250DN
call brother and tell them that the drum is shadowing and needs to be replaced or you can look in your area for a cartridge World and pay them to remanufacture that drum and If you are going to be printing check you really need to find a printer that has micr toner it has more metal ion the toner which makes it burn hotter.The toner that you are using may possibly be able to be lifted and info on the check could be changed.Bgcw@msn.com
Jan 12, 2008 | Brother HL 5250DN Laser Printer
Unknown Compatible Hp Ce255x-micr For Hp P3015 / 3015d / 3015dn / 3015x 12.5k Logo
154 people viewed this question
Top Unknown Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Unknown Office Equipment and Supply Expert? Answer questions, earn points and help others
