Question about Acer TravelMate 223X Notebook
My cd/dvd drive quit working. I've uninstalled and reinstalled the driver through the update but still nothing. Is there anything else I should try?
  • Misterixas May 11, 2010
    Do you hear the spin of disk when you insert it? Does it rejects both types of disk,- CDs and DVDs?
  • 40 Answers
Try deleting the upper and lower filters. These are registry files that help your system manage your cd drive, and sometimes they become corrupt and stop your system from correctly identifying your cd/dvd drive, or inhibit its propper functioning. Follow the steps from microsoft located here to safely complete this task: http://support.microsoft.com/kb/314060 (under advanced troubleshooting)!
Posted on Jan 25, 2009
Optiarc 7580s dvd does not recognize any disk
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Mar 04, 2012 | Sony Optiarc Computers & Internet
My compaque presario cq40 dvd drive stop working. Do I've a chance of repairing it or have to replace it.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 01, 2011 | Computers & Internet
The CD/DVD drive doesn't work at all! It doesn't read Cds, DVDs, nothing. It doesn't even open or make noises or anything. It shows up on My Computer and Device Manager but doesn't do anything. I have...
make sure that the dvd is getting enough power test all leads that are attached to the dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 26, 2011 | HP Computers & Internet
CD DRIVE IS NOT WORKING. WHEN A CD IS PUT IN, IT CLICKS THEN IT DOES NOTHING. I TRIED RESEADING IT THEN CLEANED LENS AND NIETHER HELPED.
you might have to physically unplug the leads for this cdrw/dvd rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
if your computer came with a motherboard disc the drivers could be on it
make sure that the dvd rw is getting enough power test all leads that are attached to the dvd rw including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd then plug them back in or
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 19, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I can't work with my DVD Drive LG HL-DT-ST DVD RAM GH22NS50. It is saying (Code 10) thanks
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Jan 25, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
When I put a dvd in my laptop it spins but wont pull anything up to play it. It sounds like its trying but nothing happens. I used to could open my media player and then it would detect the disc but now...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 30, 2010 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
When i put cds in it works when i put a dvd in i go to computer the drive shows nothing but when i put a blank dvd in it shows it but cant burn nothing to it
hope this helps
Dec 27, 2010 | Lite On LH-18A1P DVD RW Dual Layer Burner
I can see the dvd/cd drive but it will not play anything.when I click the drive it keeps asking to insert a disk when I have already put one in?
hope this helps
Nov 29, 2010 | eMachines ET1161-03 PC Desktop
Its not picking up the sat harddrive or the cd drive
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall as for sata hard drive
control panel admistrive tools,computer management,device manager scroll cd/dvd rom drives right click you can update driver disable or uninstall select properties from there you can troubleshoot or select driver you can update roll back driver uninstall if at any time you see a yellow question mark? you need to install a driver
hope this helps
Oct 23, 2010 | Asrock K7VT4A-Pro Motherboard
My CD Drive is no longer working it says code 39. I also tried my external DVD drive it says code 39 as well. How do I fix this?
hope this helps
Oct 21, 2010 | Compaq (120192-B21) CD-ROM Drive
Acer TravelMate 223X Notebook Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
