Kitchen Ranges Logo
A
Anonymous Posted on Jan 17, 2013
Wolf range hood halogen lights are intermittent. Have changed bulbs about 12 times over the last year but still intermittent.
Why are these lights so intermittent? Is there a board assembly problem? Manufacturing defect?
5 Related Answers
Anonymous
  • Posted on Dec 28, 2007
SOURCE: How do you change a halogen bulb in my dacor range hood
Believe it or not - they just unscrew like regular light bulbs. There is supposed to be a suction cup that came with the hood to replace the bulb - we lost ours. I was able to remove it by using a little bit of pressure on the face of the bulb and twisting it back and forth. The other bulb was stuck, so I made a "handle" using duct tape on the face of the bulb.
Anonymous
  • 139 Answers
  • Posted on Jan 27, 2008
SOURCE: Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Anonymous
  • 247 Answers
  • Posted on Apr 05, 2008
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
A.
shaggyrat
Christophe Thompson
  • 1224 Answers
  • Posted on Jun 01, 2008
SOURCE: Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Anonymous
  • Posted on Oct 10, 2009
SOURCE: Dacor IVS1 Vent Hood - How to change a light bulb?
Buylighting.com, JDR120V-75W-E27CG...also comes in 50 watt. They aren't inexpensive, but if installed properly, will last a while. We have a little suction cup to take them out and put them in. It came with the range hood. If you get fingerprints on a halogen bulb, it can blow out quicker.
COOKER ISLAND RANGE HOOD GL9002 4-12V. HALOGEN BULBS GO OUT THAN GO ON, NO OBVIOUS SIGNS
* Check your warranty. Call for service.
*** following is for information only.***
* Range hood lamps are usually available at hardware stores; Lowe's, Home Depot, or a lighting store. Take the old bulb to store for an exact replacement. There are many different bulbs though these are common for track lighting, etc.
* Note; not all range hoods us Halogen. You will find LED lights starting to show up on hoods. I'm not convinced they are the best choice (LED) for a heated area as LED is an electronic device that is sensitive to heat. Halogen's have another use (used under the hood). They do produce heat as with counter top heat lamps used at restaurants. Though not a lot of heat, you can still feel the warmth from Halogen lamps when turned on High settings.
* Golden Vantage (specs); https://www.amazon.com/ask/questions/asin/B00ASQJ7RS/2/ref=ask_dp_iaw_ql_hza?isAnswered=true#question-Tx2BW19EX2L2JVQ
Aloha, ukeboy57
1helpful
My Sirius Range Hood has two lights that take G4 Halogen bulbs. Is there a 115V bulb made for this application or is there something that converts the voltage to 12V?
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb is just as bright but runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Instruction manual KuKoocooker hood light bulbs
Just look this youtube video, and it can't be more clear.
Don't forget to unplug the hood, or switch it of. Although the halogen lamps are only 12 volt. In the hood are dangerous voltages. How to replace cooker hood halogen bulb or lamp
Need replacement halogen lights for SU3
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
2helpful
2answers
I need a halogen bulb to replace the original one in my nexstyle range hood
So where do we buy the bulbs? We've been looking for ages. Thanks.
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
5helpful
How do you replace the light bulbs? There is a lens cover over the bulb.
This is how to replace the lights on the KitchenAid khlu162m hood. If this is not you hood please give the right make and model # so I can get you the right info.
Replacing the Halogen
lamps:
The hood liner uses 12-volt, 20
watt halogen lamp bulbs.
Before you begin, make sure that
the range hood is turned off and
that the lamps have had sufficient
time to cool.
To replace a halogen lamp:
• Remove 2 screws from the
circular metal trim around the
lamp assembly.
• Pull the trim with the lamp
assembly attached down far
enough so that the lamp can be
pushed out of the socket clips.
• Insert the new lamp into the
socket clips and push the lamp
and trim assembly back up into
the hood.
• Replace the screws.
Good Luck and please rate 4 thumbs up for the free answer.
Problem changing halogen bulbs on perla rangehood
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
16helpful
3answers
5helpful
3answers
Halogen Lights Failing
I had the same experiences with my lights. I placed a 50v bulb and it blew the fuses. The fusees located on the right side of the bottom duct cover. use 5a 125 v fuse GE part # wb27x10542 but you can find a cheaper fuse at Radio Shack. Good luck
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
