Question about GE WHRE5260E Top Load Washer
What is the capacity for a GE washer WLSR3000G0ww
WWRE5240D1WW. What is capacity in cubic feet?
On the GE appliance support site, they list a WWRE5240DWW washer with a 3.5 cubic foot capacity. There is also a WWRE5240DCC with the same capacity. Based on the parts list for various GE washers with similar model numbers, the WWRE5240D1WW is also a 3.5 cubic foot washer and is minimally different from the other washers.
I hope this helps.
Jan 24, 2016 | GE Washing Machines
How do I set water temperature for the rinse cycle?
I suppose you have looked at the owners manual, on the page below, it seems to indicate knob B. but it is unclear
GTWN4250DWS GE 3 9 DOE cu ft stainless steel capacity washer GE Appliances
Dec 24, 2014 | GE GTWN4250DWS 3.9 cu. ft. capacity top...
What is the capacity of the GE Profile WPRE6100G?
• King-size, 3.5-cu. ft. stainless steel basket makes room for more items, which
means less time doing laundry
Oct 25, 2014 | GE Profile WPRE6100G Top Load Washer
How to repair drive belt on GE Profile washer
Contact the GE Washer div. and request a schematic of the machine. It will show you the detailed format for removing parts and construction teherafter.
Mar 25, 2014 | GE Profile WPRE6150KWT Colossal Capacity...
Do I keep my old Kitchenaid extra capacity or keep the new GE GTWP1000
The GE has a capacity of 3.3 cubic feet. You did not list the model of the kitchenaid. Make sure the GE was stored correctly because if it might have lost oil or gotten brittle belts or gaskets. Also it might have frozen.
Feb 22, 2014 | Washing Machines
I have a GE WPSR3100 washer...need to know the cubic feet capacity size?? please help
According to a spec sheet I have from GE when we bought it eleven years ago the capacity is 3.2 cu ft.
Nov 29, 2010 | GE Profile WPSR3100W
I have a GE top loading washing machine model # WLSR3000G0WW. It just went out of balance because it was mis-loaded. Now, even with no clothes in it, it wants to shake. I have the front off the machine and...
The back legs are self adjusting. If it shook violently then they most probalby came off the ground and re-adjusted. The fix is easy. Drain the system. Left the back of the washer off the ground to ensure both back legs are level. Now ensure the front are level by turning them until the machine is level. If this does not work then you need to manual adjust all four legs.
Dec 04, 2009 | Washing Machines
Walking ge super capacity plus washer
the drum straps are probebly broken just remove the front then remove the 2 1\4 inch screws that hold the top on remove the top the straps are located on top of the tub they are black rubber
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
What is the load capacity for the GE WPSE4200AOWW Washing Machine?
not sure exzakley ive repaired thousands of washers though.just dont pack the clothes in it.God bless,tom
Jan 01, 2009 | GE WHRE5260E Top Load Washer
GE WHRE5260E Top Load Washer Logo
132 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
