Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Service code FP
I have an amanda TPAC 12000 with a service code on the display of FP. the fan works continually, but no heat. eventually, the heat starts or sometimes not. but as long as its plugged in, the fan runs.
  • antonydel Feb 26, 2009
    I have the same issue with an LG PTAC unit. I called LG technical support and they did not have an answer.
I know some manufacturer's use the code FP for Freeze Protection.
Posted on Feb 27, 2009
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Whats with norpole 12000 btu window air conditioners w/FO CODE,now all i have is a expensive fan!
they eventually do need serviced by a good repairman .freon leaks out .control boards fail etc .
Jul 18, 2016 | Filter Heating & Cooling
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
Compaq presario cq62 won't start but the caps lock led blinks continuously and the wifi led remains on continuously, tried new cpu, worked for a while and started same problem again.
those are blink codes, learn to count them.
if you pulled the CPU i bet you that you used the wrong heat sink compound.
The CPU shuts off all by itself if too hot. your job is to get the fan working and the heat sink working and that thermal compound right.
hp.com
as the blink codes we are not HP here, ever
https://support.hp.com/us-en/document/c02222922
Jun 01, 2017 | Compaq Presario CQ62-209WM
What is a E4 code mean
Error Code:
E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System
will shut down.
E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling
operation will be locked out. Fan operation can continue to operate.
E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation
will be locked out. Furnace, heat strip, heat pump and fan mode of operation can
continue to operate but displays the last temperature set-poi
Dec 18, 2012 | Dometic 3313192.000 White Single Zone LCD...
I have installed an LMU246 with two heads. One 9000 BTU and the other is a 12000 BTU. The 12000 seems to work fine but the 9000 head dosent cool and when I tried it on heating, a c7 code comes...
with the Lmu24 you have a variable speed compressor i wouldn't suggest attacking this repair on you own, get a Nate certified Sr. service tech out there and have them do cause your taking about high end cutting edge compressor technology, how ever if you need them i can email you a pdf copy of both owners and service manual.
Oct 01, 2010 | LG LS-K1830CL Cool Mini Split Air...
Our Zanuassi zob 1060 oven has stopped heating on all elements. Fan and display still works, eventually an error code E80 appears
Check that the timer is set for Manual/not auto...Next if no joy could be heating element, check with multimeter should read about 2 ohms if okay...
Apr 12, 2010 | Zanussi ZWF1440 Front Load Washer
Won't run
found a pf not an a fp
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Apr 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
787 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
