Question about Kitchen Ranges
We have inadvertantly switched the oven to pyrolysis when cooking.
Hi FixYa;
My husband had inavertantly turned the oven switch, on our De Dietrich Oven, to the pyro setting and once this is done you are unable to undo it until about 3 hours later, when it has run it's course.
However with Rylee Smith's help - between us we worked out that if we turned the oven off immediately (which we had done as soon as we realised our error) and unplugged it from the mains if necessary (not in our case) and then waited for the three hour time limit to expire then, we could open the oven. This is what we did.
On the oven casing when the pyro is used - a red warning light also comes on and you can only open the oven when this has gone out.
The "Pyro" is for automatic cleaning of the oven.
The turning on of the Pyro is absolute and there is NO undoing it once it is locked in place - we contacted your firm in the hope that we could by-pass the Pyro but as we found out - with Rylee's help - it is just not possible.
I was very appreciative of having someone to talk to whilst we sorted out the problem and can't thank Rylee Smith enough for his patience in dealing with my query.
Yours sincerely,
Margaret Dean
Posted on Jan 26, 2009
I have a de Dietrich double electric oven with pyrolysis. I did a clean and now the bottom oven won't heat and fan not working. Top oven is fine, thank goodness
Many times when the self clean function is used they seem to melt connections internally . call your local repair company and have it checked out
Sep 24, 2016 | De Dietrich Ovens
How do I get the ovens working if the clock works, but they do not?
You'll have to make sure that the clock has been set for Manual cooking and not inadvertently set it on Auto. However if your breaker tripped because of a fault on your oven the internal switching of the timer may have been damaged as a result of the fault.
Nov 10, 2014 | Viking VEDO205 Electric Double Oven
Kitchenaid KEHC309 -oven stops working just after starting, and 'insert probe' warning appears. I ran a cleaning cycle to remove any moisture from the oven, but that did not solve the problem. My oven is...
I had another brand with that fault from new. We disconnected the probe wiring from the control board and it stopped looking for it.
Also, could be a setting has been changed inadvertently.
Oct 14, 2013 | KitchenAid Architect® KEBS277S Electric...
Neff B4562
Engineer is a solution.
The other solution is;
Switch 3 times between rotisserie and pyrolysis or bread baking setting and pyrolysis.
As acknowledgement the displays are actuated.
At each change of operating modes switch immediately stops the current test step and the next step of the test enabled. The oven light should according to the mode ON or OFF; that is, at pyrolysis OFF otherwise ON.
Jul 01, 2012 | Ovens
I have a older Frigidaire oven model #RG74BC. I have messed with the timer knobs and the oven will not come on. Does anyone know what setting the knobs need to be on to fix this problem
You have probably inadvertantly put the oven into Automatic cook mode, where the oven will not come on until a preset time.
Try pressing/turning the clock/timer buttons and resetting the clock and this should put the oven back into Manual cook mode and you should be ok.
Jan 10, 2010 | Ovens
My oven will not move from SAb o 5A6 and buttons
You have inadvertently entered the Sabbath Mode.
Try holding the clock button for 5 seconds to clear it out.
Dec 12, 2009 | Jenn-Air JJW7530DDS Electric Single Oven
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Bottom oven door won't open
Started the pyrolysis cycle for 1 minute and then cancelled it. The door then unlocked.
May 25, 2008 | Gaggenau EB294/295 Electric Double Oven
Kitchen Ranges Logo
135 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
