Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum
Problem for Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum
Drive belt ; whirlewind litespeed.
By ronnie_obier on Jan 25, 2009
is there supposed to be something on the end of the motor shaft,
where the belt goes around it. to keep it in place, and to keep it
from breaking so easily.
Solution #1
posted on Jan 27, 2009
Not Rated)
lysager
Rank: Guru
Rating: 98%, 30 votes
There is nothing but the motor shaft. The belt rides on the shaft and around the brush assembly on the other end. The belts fail if the brush assembly gets jammed, for example from a rug ot debris. If this occurs you should immediately turn off the unit,unplug the power cord, and clear the jam. Also occasionally cleaning the brush and being sure the bearings on each end turn freely will help prolong belt life. The brush assemblies also look to be available. lysager@gmail.com
Was this helpful?
Yes
No
Popular Solutions for Eureka Whirlwind 4388 Bagless
Questions and Unsolved Problems for Eureka Whirlwind 4388 Bagless
Do you recommend Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum?
Answer
Answer
The rubber sponge like substance that helps seal the canister on the top is damaged. How do you get... (More)
Answer
MY 4388 WILL NOT PUT DIRT, DOG HAIR, ETC. INTO THE NON CONE SIDE LIKE IT ONCE DID, SEEMS CLOGED... (More)
Answer
how do i empty the cup ,it is bagless and i dont know how to pull it apart
Answer
We have a Whilwind model 4380. The belt broke and and also the black plastic part that attaches to... (More)
Answer
My eureka whirlwind 4388 vacuum keep plugging up from the head to thehose fitting. How can I get... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Eureka Whirlwind 4388 Bagless...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
