Question about Kenmore 22422 Top Load Washer
I have a kenmore series 90 and the agitate and spin will not work, you hear a humming noise or maybe a slight grind
  • 5,911 Answers
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. The humming sound you hear when the lid is closed may just be the timer motor running. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured. I hope this helps you.
If you determine that your lid switch is broken, please let me know and I will provide you with the steps necessary to repair it yourself (simple repair job). I can also give advice on where to purchase a replacement.
Posted on Jan 27, 2009
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
Kenmore Series 90 washer. Will pump the water, does not spin
Replace the motor coupling between the motor and transmission its very easy if you tilt the machine back and remove the two screws holding the motor brackets.
Mar 28, 2009 | Washing Machines
Tub won't agitate and when it does spin, makes a grinding noise.
its probably in the gear case. or spin tube bearings. did you see any oil leaks on the gear case or clutch and break area.
Feb 07, 2009 | Kenmore 24032\24036 Top Load Washer
Squeaking/grinding/rattle noise during wash and spin
That sounds like a clutch problem - probably just worn and need replacement. Will definitely need to pull to find exact fault.
Regards
Nov 16, 2008 | Washing Machines
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Kenmore 22422 Top Load Washer Logo
77 people viewed this question
Sal De
fordexpert
Robert Rankin
