Question about HP PSC 1410v All-in-One Printer
Printer will not cancel print job
I tried to cancel the job it did not print but in the print queue it says deleting . the same job has said deleting for multiple days
  • HP Master
  • 419 Answers
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
Posted on Jan 25, 2009
I cancelled a document while it was printing and it is still in my queue days later as deleting and it wont let me print anything else or restart that print job.
The best way to delete the print job is to turn the printer off, then disconnect the cable from the printer to the computer. Turn the printer on with the cables off, and go to your computer and delete the document, Then once it's deleted, turn the printer off again, and then hook the cable back up. Then turn the printer back on. That should do it.
Good Luck
Mark
Sep 13, 2014 | HP deskjet 3940 color inkjet printer -...
HO C4200 DOCUMENT STUCK IN QUE CAN'T DELETE
First You Need to Open the Print Queue, follow the below steps on how to open a Print queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double click on the appropriate printer to open up the Print queue,Check whether you have any pending or the queued jobs, try to cancel the jobs by following the below steps.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
• To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
• To cancel all print jobs, click Cancel All Documents on the Printer menu.
If you are using an HP printer and a windows vista operating system then you are lucky to automaticlly fix the issue with the HP Print Diagnostic UtilityClick Here For How to cancel printing or to delete a print job that is stuck in the print queue in Windows XP.
Alternatively You can check the below steps.
Delete Pending Jobs
How To Restart Spooler restart In Windows Vista
Click the Start button.
Click Control Panel.
Click System and Maintenance.
NOTE: This step is not required when using Classic view in Windows Vista.
Click Administrative Tools.
Double-click Services.
On the User Account Control window, click Continue.
Click Print Spooler.
Click Stop to stop the Print Spooler.
Click Start to restart the Print Spooler. Then click Restart
Click OK
Hope this helps!
Thanks!! - See more at: http://hpanswers.blogspot.com/2008/10/cancel-and-delete-stuck-print-jobs-in.html#sthash.QD3KNI9q.dpuf
Jul 01, 2014 | HP LaserJet 4200 Printer
Printer was working, but is not now. All cables are hooked up properly and have been disconnected and reconnected. I have several documents in the memory to be printed, but the printer will not respond. ...
Here are four things you can try; may not have to perfom all:
Check to see if your printer is off-Line
1.Open the Printers, Printer and Faxes, or Device and Printers folder.
To do this:
Windows XP users; Click on Start > Settings > Printers an Faxes or Start > Control Panel > Printers and Faxes.
Windows Vista users; Click on Start > Control Panel > Hardware and Sound > Printers.
Windows 7 users; Click on Start > Device and Printers.
2.Right-click on the printer object (icon), and select Use Printer Online.
3.Microsoft Windows 7 users will double-click on icon, select printer and then de-select Use Printer Offline.
Printer Paused
The printer or print queue is paused and the print queue icon remains in the notification area ('systray') of the task bar.
Explanation:This is typically an end user error. Hint: Dragging the mouse cursor over the print queue icon in the notification area will reveal (1,2,3) document(s) pending for (User name).
What to do:
•Double-click on the print queue icon to open the print queue.
•Click on Printer in the upper left-hand corner of the menu bar.
•Is there a check mark next to Pause Printing?
-If yes, click on Pause Printing to turn off this Windows feature.
-If no, confirm that there is a check mark next to Set As Default Printer and make sure Use Printer Offline is not selected.
Delete print jobs from the print queue
Access the print queue.
Delete all print jobs
• Click on Printer in the toolbar and then click on Cancel All Documents,
or
• Right-click in the print queue and select Cancel All Documents from the pop-up menu.
You can also delete individual print jobs
1.Highlight the individual job in the print queue by clicking on it.
2.Right-click on the highlighted job and select Cancel from the pop-up menu.
IMPORTANT! If a job is stuck in the print queue and cannot be deleted or canceled using the above steps, there may be an issue with the printer spooler that controls the printing options in Windows. If you observe this symptom, it may be necessary to stop and restart the print spooler; then retrun to delete print jobs.
How to Stop and Restart the Print Spooler
Problem:
Unable to cancel print jobs; Unable to print; Print queue is unresponsive; Locked print queue; Unable to print; Cannot cancel print job; Printer driver not responding
Solution:
The print spooler controls print options within Windows. A problem with the print spooler can affect printer driver performance and Windows print queue responsiveness. Stop and Start the print spooler to see if observed symptoms subside or remain.
Method 1: Using Administrative Tools
Step Action
1 Click on the Windows logo start button.
2 Click on Control Panel on the right-hand side of the start menu contents.
3 Click on Maintenance.
4 Click on Administrative Tools.
5 Click on Services. NOTE: You may have to provide an administrator profile and password.
6 Scroll through the list and look for Print Spooler.
7
The following two options are available to stop and start the print spooler:
•Click once on Print Spooler to highlight it, and then click on the Stop or Start links in the right-hand window pane,
or
•Double-click on Print Spooler, and click on the Stop button followed by the Start button.
8 Observe the status column in the Services window to verify that the print spooler is stopped or started as applicable.
Trust this helps to resolve your problem. Please vote.
Dec 29, 2010 | Lexmark X5495 Printer
I have a HP 4385 --how do you cancel a print job---it was sent a print job multiple times (over 10) from a Mac and i do not know how to cancel these jobs as they were sent in error and are huge ink...
The printer should have a stop/cancel buttom on the panel, just press that and it sould cancel the print job.
Also, you can delete the job queue from the computer. You should have a printer in the Dock, click on that and select jobs and click on the delete button. If you don't have the printer on the Dock, click on Apple, System Preferences and select Printers. Select your printer and click on Open Queue and delete the jobs from there.
Dec 02, 2010 | Office Equipment & Supplies
How to i clear the queue with jobs waiting to print when the printer says printing but is not printing
Try pressing cancel on the printer first. Then, open the print queue by opening the printers folder, and double-clicking the printer icon for your printer. Try to select the jobs there and cancel them. If that doesn't work, turn off the printer, and wait for the title bar of the print queue to say "use printer offline". If it doesn't change on the title bar of the queue, then select "use printer offline" from the file menu of the print queue. Then try to delete the print job. If this still doesn't work, leave the printer off and reboot the computer, then try to delete the print job again if it is still in the queue. If none of these work, remove and then reinstall the printer as a last resort.
Sep 30, 2010 | HP Officejet 5510 All-In-One Thermal...
Cancelled a job and it stays in queue
Cancel all the documents in the print queue, (just do it whether they are actually deleted or not), press "cancel" on button the printer and restart your system and also the printer. If possible, please leave the printer switched off for few minutes and don't forget to use the "Power" button to turn if off or on. This will help your printer to restart new print job, all the jobs on the print queue will be deleted/cleared. Good luck, Thanks for using FixYa.
Jun 08, 2010 | HP DeskJet 5550 InkJet Printer
I'm unable to delete a job from the queue. And therefore, I'm unable to print anything else. Any ideas of what to do? Thank you!
Open the print Queue, click the print job that is hanging and then from the menu, I believe under file, click pause. Once it is paused tried to delete the print job.
Sep 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printer Queue blocked by 'Deleting' problem
THere is an easier solution.
Restart the printer spooler service. THis solves problems very often
Jan 21, 2009 | Samsung CLP 300 Laser Printer
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
Can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
HP PSC 1410v All-in-One Printer Logo
1,983 people viewed this question
Ben Johnson
