Question about KitchenAid KGSA906PSS Gas Kitchen Range
I tried the self cleaning feature on a w256b model Jenn-air oven and a F8 fault code beeps and now the oven door is locked and won't open. I have replaced the timer but now I get a continuous blinking message door, door, door on the display. What else could be wrong? cleaned the oven door wont unlock tried what the manual said  control panel is black, also the meat probe does not work
  • 535 Answers
For me...I disconnected the fuse. The F8 code would come on and off again with no consistency...after about 6 months I forgot about turning off the fuse....guess what it corrected it self and has been fine for 2 years now. I had got a quote on replacement of this panel...6000 to 700 $$$$$ I don't think so!
Posted on Jan 25, 2009
    Brigadier General:
  • 8,619 Answers
Hi
1. Let it cool down and it should open, if not.
2. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker then try moving the door lock lever or opening the door if there is no lever.
3. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Try moving the door lock lever or opening the door if there is no lever.
    Genius:
  • 1,199 Answers
Unplug and let cool down! oven door will open when cool and oven will reset itself!
Jenn Air W256B error code F8
Hi, F8 on later model jenn-air ranges/wall ovens indicates an issue with the meat probe, usually the resepticle. The fault is sensing a temp. at the probe above 250. Unless you actually have the meat probe inserted into the recepticle and the oven has heated above 250, then it's not likely the meat probe itself. Hence why the recepticle is likely faulty or in need of inspection/adjustment. Here's how (this may or may not work...sometimes it does though). First unplug the range or shut off the power to it. **The probe is attached on the oven liner via a nut, however you,ll need to gain access to the outer side of the liner by removing the side panel if the recepticle needs to be replaced, but hold on.** You nay only have to loosen the nut and re-tighten it to insure the recepticle has a good "ground" to chassis. there is only one wire attached to the other side (you can't see it) because the probe converts temperature to resistance in the control, that is why this "ground" is essential and can cause "faults" if not secure/sufficient. At times that's all it takes to force an F8 code. Try this first, reset the power and see if it yields a successful remedy. Hope that helps, good luck Hope that helps, good luck
Oct 03, 2009 | Kitchen Ranges
Jenn-Aire locked tight!
that relay/solenoid can get stuck quite easily..
you have a service contract on this?
Mar 28, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
Try turning the oven tempurature all the way to the right (past clean). That is what unlocks mine.
Jan 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
KitchenAid KGSA906PSS Gas Kitchen Range Logo
56 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
