Question about Kenmore 24032\24036 Top Load Washer
Kenmore quiet pak III dishwasher has a whining noise
I have a kenmore quiet pak III dishwasher, it started with a whining noise while in the wash cycle. I took the entire assembly apart inside and removed some debris but it still has the noise.
  • 27 Answers
Most of these dishwashers have separate circulation and drain pumps and there is a good chance that there is an issue with the circulation pump impeller issue under the lower wash arm. The bottom panels under the door can be removed to check it out.
Chris Z ---
Posted on Jan 26, 2009
My washer make noise to loud when It spin mode. how to fix it
what does the noise sound like is it a high pitch squeeling noise or grinding. need more info
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My Quiet Partner III dish washer gets very noisy while filling up with water at beginning of rinse or normal wash cycle. That noise lasts for about 1 minute upon starting only. Would it be a faulty...
yes its a bad inlet valve. sometimes you can turn down the house valve the washer is connected to a little to stop the noise.othe then that replace the inlet valve.
Feb 27, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Groaning washing machine
You may have something in the food shredder thats causing the noise.If you remove the bottom panel and look  at the right side about half way in you'll find the pump.You can remove it by hand because it twists off for quick access.MAKE SURE POWER IS OFF FIRST.
Apr 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Does not appear to wash
is there a low humming noise when it should be washing? if so may be the motor capacitor
Apr 02, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore 24032\24036 Top Load Washer Logo
351 people viewed this question
Sal De
 Brian Main
Brian Main
