I have a Rheem HVAC. The blower is running, but the spark thing will not light the burner. My unit is about 4 years old.
  • Ken Bledsoe May 11, 2010
    does it spark at all?
    Scholar:
  • 144 Answers
Welcome to Fixya. It sounds as if one of the limit switches has opened. Did you have a dirty filter? Limit switches are mounted on the fire box(box around the burners) and around the middle of the furnace in front. They may or may not have a reset button on them. First turn off the power. Then if you see the limits with buttons go ahead and reset them. If none of the limits has a button on it tap the metal next to it (don't hit the limit or it will break) this may jar it enough to reset it. You can also jump them out by removing the wires from the terminals and joining them together with some elec. tape. I DO NOT recommend running your furnace with a limit bypassed. This is for diagnosing only. Please let me know if this helps or not.
Posted on Jan 25, 2009
Rheem powervent 42vp40f does not provide water to all faucets
Feb 2013
1) Copy following links for Intellivent gas control service manual, low hot water pressure, and crossover:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/Crossover.html
2) Unknown if tank has hot water > that is first thing to check.
3) Unknown if air intake screen located under burner is clogged with dust that cause combustion chamber to overheat, tripping FV lockout and breaker TRD glass vial.
Requires removal of combustion parts, replacement of TRD, blow out air intake screen, reset intellivent
4) Unknown if there is error code.
5) Rheem does not post service manuals.
However this unit can probably be repaired.
Feb 05, 2013 | Water Heaters
Weak ignitor spark at 1 burner
What is the model number of the unit?
Nov 29, 2012 | Kitchen Ranges
Heater does not function when C8 code appears. How fix?
This is a circuit board problem you will need to contact rheem
Aug 10, 2010 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
New gas water heater pilot light will not ignite
Hi .. if this is a brand new heater, then you probably need to have the gas line bled. This means getting all the air out of the gas line feeding the burner. This can be done by constantly trying to light the burner or poilot . or it can be bled down by a HVAC tech.
Apr 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
RHEEM OIL FURNACE MODEL ROBD 067 LBEA BLOWER
You will likely need to install an isolation relay in the W circuit from the thermostat. Some thermostats rob a small current through the W circuit to power the thermostat. This small current can be enough to start the fan circuit timer. You can test this by disconnecting W at the furnace and allowing the timer to shut down. If the fan shuts off with the W disconnected you can install a simple relay.
The relay coil will be connected to Common on one side and the W from the thermostat to the other. Then you will run a wire from R on the furnace to the relay and from the N.O. Contacts to the W terminal on the furnace. This will kill that signal that is starting the timer and the W can steal it's power through the coil back to common.
Dec 23, 2009 | Honeywell Electronic Programmable...
Tankless water heater (Paloma) Has C2 11 error
I had this problem with the C2 11 error code. My unit is 1.5 years old. I called Paloma and they emailed me an 11 page document to clean the burners. I am not an HVAC but I got the feeling that's who the instructions were for. Very difficult but you can do it if you're handy. You basically take apart 1/2 the unit, be carfull not to lose any screws and label all the little brackets that come off. It took me 2-3 hours to get to the burners. I used a can of air (for keyboards-electronics) to blow on the burners and clear any build up. After putting it back together (carefull to make sure the 3 gas tubes make a seal when re-installed) the unit works. I did this today so I'm not sure the unit will still work in a week/month. I am dreading having to do this every year to keep the unit running.
Sep 28, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Remote is displaying C7 76
Contact Paloma/Rheem customer (800-432-8373) support and notify them you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support. However, I do have a detailed process on how to repair the printed circuit board yourself. Any further questions, you're welcome to email me at jzklipper@aol.com .
Good Luck, if this has helped you in any way...please indicate so.
Aug 22, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem A/C unit makes a clicking sound when
Shut down the unit and turn the power off. Take the cover off of the blower housing and feel around within the squirrel cage. It sounds like something may have been drawn up into the blower. Also it is possible that the blower wheel might have thrown a balance weight and caused the wheel to become unbalanced. It could also be the motor about to go out but since I can't hear it myself, I'm trying to cover all the bases.
Mar 22, 2009 | Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
