Question about Emerson Televison & Video
Emerson tv audio output
Are the RCA audio jacks on the back of tv audio outputs
  • 10 Answers
SOURCE: RCA L26WD26D
Did not work..
Posted on Mar 12, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Which external speakers work with an Emerson 19" LCD digital TV?
Coaxial digital output is not a speaker-level signal, and you don't connect speakers directly to it. It's an output signal meant to feed an amplifier which takes that kind of input. You then connect the speakers to the amp and select the digital input, the same as you connect a CD player and select that when you want play a disc.
Posted on Feb 13, 2009
  • 87 Answers
SOURCE: No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Posted on Apr 20, 2009
  • 12 Answers
SOURCE: The T.V. only has one audio out jack on the back
If you are sure that is a digital out, then plug it in a digital input of your receiver.
Posted on Jul 23, 2009
Warf135
  • 137 Answers
SOURCE: When I use the headphone output jack (to drive a powered subwoofer), the default internal speaker audio output is disabled, leaving me with only the subwoofer output. How can I use both the internal
Your best option is to use a seperate amp with sub output from the audio outputs on the back of your TV. use this amp to power the sub and a good pair of speakers, and you'll have quality sound.
It is possible to prevent the TV's internal speakers from cutting when you use the headphone socket, but it means going inside your TV, and if your not skilled, you can easily blow your TV (and yourself) up. You just need to re-wire the headphone socket on the TV to stop it cutting the internal spaekers.
Posted on Oct 06, 2009
I bought a LG Blu-ray player and have Emerson TV it doesn't have a HDMI port in the back. It only has I believe they're called RCA jacks & Svidio plugs what do I need to hook the Blu-ray player up
If your Emerson TV has L. audio, R. audio, and video RCA connectors on the rear panel, the corresponding outputs from your LG player go there.
Jan 19, 2017 | LG Televison & Video
Cant connect a rca soundbar to my emerson tv
If your Emerson TV has a digital coax output connector identified as such and your RCA soundbar has a digital coax input connector, you will have to purchase an appropriate cable and connect it. Some soundbars, such as Vizio, have left and right RCA audio inputs to match similar outputs on a TV set.
Jan 09, 2014 | Televison & Video
How to hook it up to new emerson tv without s-viedo connection
Hi,here is my solution...
If you want to listen your TV on your Stereo system thru your receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the Receiver..
If you want to display your DVD on the TV,than do everything visa versa..as;
**connect "Video Output " RCA jacks or "Optic cable output" of your Receiver
** to "Video input " or "Optic Cable input"
of your TV and make a selection corresponding input of TV
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up to continue f
or Helping out the Community :)
Apr 10, 2011 | Curtis DVD6041 System
Don't know how to connect to tv
If the TV has audio output available, there will be RCA jacks somewhere for that. The standard colors are red for the right channel and white for the left, and they'll be clearly marked as audio outputs. Not all sets have audio outputs, though, while they usually have audio and video inputs. So if you find RCA jacks on the set be sure to see how they are marked.
If the TV has output jacks, all you need is a cable with the appropriate plugs at each end. The TV needs RCA plugs, while the input connector to the speakers varies by manufacturer. Typically the speakers will use a 1/8-inch stereo jack if they were made to be used with a computer, and RCA jacks if they were meant to be used in a home-theater setting. In TV sets with audio outputs, the output may be fixed and independent of the TV volume, which means you can turn the TV volume down and use just the external speakers. Or the audio output may vary with the TV volume, meaning you'll always need to have the TV volume on as well. Some people find this annoying.
If the TV doesn't have an audio output available, you can't hook the speakers to the TV. What most people do in that case is use the TV as a video display in conjunction with an AV receiver. The audio and video sources connect to the receiver, which in turn drives the speakers and provides a video output to the TV.
Feb 27, 2011 | Durabrand 5.1 Surround Sound Computer...
I want to connect my tv to my stereo for sound but it is not working in aux mode can this be done
Your TV must have a sound output, preferable an RCA type output jacks, these are connected to aux or line inputs of your audio amplifier, in some TV sets, you must deactivate speakers at menu to have audio at these outputs, please check your TV user guide for more details.
Feb 20, 2011 | Emerson MS3100 3-Disc CD Changer
Im trying to find an audio output for my tv or a headphone jack but with so many things on the tv i cant find it.. help
There should be two RCA jacks on the back for left and right audio outputs, white and red respectively, if it has stereo out. Connect these outputs to a stereo receiver or amplifier into an auxiliary port or TV audio input via a red and white RCA cable.
Nov 10, 2010 | Televison & Video
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
I have a aiwa cx-na77, how do I connect it to a tv so that I hear the tv sound on the aiwa speakers
If it has an "AUX" input or any other type of RCA jacks for an input, you can connect the TV RCA audio jacks output to the input RCA jacks of the Aiwa.
That's what you would need.
RCA audio outputs on the TV
RCA audio input on the Aiwa
Just look at the back of each unit and see if it has them. RCA audio jacks are the small circular red and white jacks. They will be labed on each unit what they are for. You need output jacks on the TV and input jacks (but not for phono) on the Aiwa.
Aug 08, 2008 | Aiwa Audio Players & Recorders
LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Sep 12, 2007 | Digital Audio 5-OUTPUT COMPONENT VIDEO...
Volume control doesn't work on the enternal speaker
On some sets that have audio output jacks, the level of the audio output on the RCA jacks is fixed, and it does not change with the TV's volume control. On some sets, such as Sony, you can choose fixed or variable output. I have also seen some sets that have both fixed and variable RCA jacks on the back. With variable audio out, the audio level at the audio output jacks follows the TV's volume control. If you go into the TV's menu and navigate to the audio page, look for fixed or variable output options. If you have the owner's manual, read the section on audio output. If variable output is not an option on your model, then the level is constant and the volume will have to be adjusted with the stereo's volume control.
Aug 25, 2007 | Toshiba 27DF46 27" TV
Televison & Video Logo
134 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
