Question about Copystar Sharp MX-3100N Copier : Sharp MX3100N Color Copier
Retractable Keyboard on Sharp MX3100N not working
The Retractable Keyboard not responsive
What does error code dc on sharp 3100n mean?
image cartridge cyan need to be replaced
Jul 04, 2014 | SHARP MX-3100N
The keyboard on my Sharp MXM363N has stopped working, how do I fix it?
The driver board just underneath the keyboard has been known to go bad. One symptom of this is that all 3 of your indicator lights at the top side of the keyboard are lit.
May 30, 2014 | Sharp MX-2300N Color Copier
Printing data light is blinking
Check if the machine print is put to paused, go to status and make sure you it is on resume not paused.
Dec 12, 2013 | Copystar Sharp MX-3100N Copier : Sharp...
Error code E7-06 sharp copier MX3100N
The problem is either a corrupt print job that the copier is trying to process or the copier's hard drive is faulty.
Firstly, turn off the copier, check all P.C's that are connected to the copier & purge any print jobs that are currently spooled on the P.C's. Next, turn on the copier & see if it comes ready. If it does, try to print a known document from a P.C. If the error occurs again then I would suspect the hard drive on the copier is faulty.
Hope this helps.
Dave.
Aug 07, 2017 | Sharp Mx-3100n Color Copier Super...
HAVE A SHARP MX3100N COLOUR MACHINE...THE PROBLEM IS I CAN SEND FAXES,BUT CANNOT RECEIVE JUST KEEPS RINGING CONTINIOUSLY..ITS ON AUTO RECEPTION
Try a new phone line from the wall to the machine. Make sure to plug it into the "line" and not the "ext/phone"
Jun 01, 2011 | Sharp MX-2700N Color Copier
I AM UNABLE TO USE THE SPACE BAR AND NUMBER FUNCTION KEYS
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Open a screen you can type on. Hold down the space bar with a small tip (like the edge of an eraser), but don’t use anything so sharp it cuts through or that will leave ink spots. Hold it down and wiggle it on the bar keeping constant pressure for about a minute or until you see a response. See if you start getting a full or partial response from the key. If you do…the problem is dirt; if not, it is either dirt or broken…you may need to take it apart to clean it out, but this is common. There are plastic guards sold that prevent the innards from getting dirty and will save you a lot of grief.
Aug 24, 2009 | Dymo LetraTAG Thermal Label Printer
Worst service response from Sharp Tv Never buy it
That's odd....I've never had a problem with Sharp, particularly the AQUOS series. What was the model number of the unit?
Dec 31, 2008 | Insignia IS-LCDTV32 32 in. Television
Copystar Sharp MX-3100N Copier : Sharp MX3100N Color Copier Logo
56 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
